Tiller size for L3901?
Carter
L3901, FEL, Snowblower
Feb 18, 2015
Grey County, Ontario
I have a L3901. I want to put in a good sized garden plot. I have been looking at disc sets, but in the course of doing so found some used tillers for sale. If I was to pick up a rotary tiller to do a good sized garden plot and maybe a few food plots I am wondering what size to get. I am looking for some useful advice on tiller size from guys who actually have one and use it?
I have found a 48" Kubota B48CA tiller used for sale, and the price is fair. Does anyone know if this will fit, and work? I can't seem to find much info online.
Thanks
cmorris1
L3901 HST
Nov 30, 2014
35
Louisville/Hart Co.
I just picked up my L3901 last week with a 60" reverse land pride tiller and it did a great job on a small plot my dad had, tilled it very well!! Now i just need to find a rear ballast box.
chris
mickeyd
Mar 21, 2014
1,192
Guin, AL
I have a LP RTA1258 and it works very well. For your size tractor you could even go up to 72 inches with no problems.
Dune33
L3800, 72 kk mower, 48" tiller, plastic mulch layer,
Jun 14, 2012
Wyoming, MN, USA
I have a 48" tiller that I used on my L1500 that I kept when I got the L3800 works great but to cover the wheel tracks a 60" would be better
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
Normally a tractor would have the HP to run a tiller that is as wide as its tires, at their narrowest setting. If you get a smaller one, get one with the side shift feature, so you can offset the tiller to one side, to cover 1 wheel track...:D
Balvar24
L3800 HST, 5ft Rotary Cutter, 5ft Box Blade, Pallet Forks, 72" Rotary Tiller
Feb 18, 2014
56
Rock Ridge
I've got an L3800HST with R-4's. The outside of the tires are about 62" or so I think. I've got a 6' Tiller. Works fine.
Carter
Feb 18, 2015
Thanks for all the replies. I have done a little more research and found that indeed this unit would be too small. Back to searching for a good 60" ++ tiller, among just about every other attachment I "need" to have. Thanks again.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
keep in mind all tillers are not made equal. I have a 62" Bushhog tiller with 4 tines per row. A KK tiller with 6 tines per row is much harder to run but do a much better job.
You should decide if you want a bigger one to cover more ground or a smaller one with more tine that will tear the ground up better. I would say a 60" 6 tine or a 72" 4 tine will work great on your tractor without putting it under to much of a load.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Reverse vs. forward till has some impact as well.
I have an L3200 and I think 60" forward or 48" reverse is about as best as I can do on it.
Fallon
L3200
Sep 10, 2013
19
Parker, CO
I have a 60 or 62" King Kutter 2 behind my L3200 HST. Works well. Its slow going, but I'm sure that's the nature of a tiller. A 72" might work, especially with the 6 extra HP. My tracks with R4s are 60", which matches most of my implements.
Fallon
L3200
Sep 10, 2013
19
Parker, CO
Oh, HST makes a big difference. Trivial to keep the go pedal pushed as far as it will go without lugging the engine. Should easily compensate for a slightly to big tiller where a gear couldn't.
