TG1860g/FD590V-ES08 Carb Question
jrossi90
tg1860g
Apr 24, 2019
Hello,
I am looking for a replacement carb for Kubota TG1860g / Kawasaki FD590V-ES08. I believe the carb part number is 15003-2721. I'm having difficulty sourcing one. Can anyone point me in the right direction?
lugbolt
ZG127S-54
Oct 15, 2015
4,843
1,598
Mid, South, USA
A lot of the John Deere equipment used the same engine. 345 garden tractor comes to mind as does the 285 garden tractor, among others. So there's a good possibility that a carburetor for a 345 will interchange. Try Deere part number AM122617. That is a number that came to mind, OTOH, and going off of my aging memory.
Kubota no longer supports Kawasaki engines; any Kawasaki engine parts that were once available through the Kubota dealer network are listed as "no longer available" through Kubota, so you have to get them from a Kawasaki engine dealer. When sourcing any Kawasaki parts from a dealer, you want ALL of the numbers off of the engine. FULL (not partial) model and serial numbers specifically.
Example: Model FC501V-BS00 and serial FC501VB23498 (etc).
When the Z122RKW-42 came out a few years ago, I was looking up an air filter for it and was quite surprised to find that it showed to be "no longer available"--as listed by Kubota's dealer system. A 1 week old mower and NLA. Since then, Kubota's updated their listing (at least through the dealer system) to where you point/click an engine part and it takes you directly to the Kawasaki system to look up the part. However, some of the older equipment, that's not the case, and a lot of times the dealer will just say "tough luck", perhaps because they're either too lazy to do the leg work, or they simply don't know....OR they're not a kawasaski engine dealer. All 3 are too common, in my opinion, particularly the first two.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
This is listed as a replacement: 15003-2183.
1,003
I have had good lock with an on line place called carbhub
You should be able to find the manufacturer name and number on the existing carburetor and then google it with that information.
You should be able to find a replacement online.
jrossi90
tg1860g
Apr 24, 2019
I ended up buying a China carb; just received. Admittedly I'm no expert but I can't for the life of me figure out where the idle adjustment screw is. I'm uploading a picture, can anyone help?
Sent from my SM-G960W using Tapatalk
1,003
It is on the top right hand side on the far side in your picture. In the bottom of the sideways “u” shaped silver piece. The end of the screw presses against the golden colored tab that is showing in the picture
That is the idle adjustment screw.
If you are looking for the idle jet adjustment screw, I’ll look into that if needed
