temp gauge not working properly
calfpen
l2800
Jun 24, 2017
ridgeland, sc
Temp gauge on my l2800 barley moves then stops and stays in the same spot and fuel guage stuck on full. Both gauges started malfunctioning at about the same time. What should I check to find the problem?
3,091
Re: tem gauge not working properly
Temp gauge on my l2800 barley moves then stops and stays in the same spot. Any advice?
Get a infrared thermometer....they are cheap...less than 20 bucks.
Check lots of places, it will tell you far better than the gauge
11,277
Most likely you have lost a ground connection, there will be a whole group of wires on the connection, remove it and clean the connections.
The other issue could be a bad connection to the back of the instrument cluster.
