Switching From Turf To Industrial Tires
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Yes the ratio is the most important thing to maintain, generally 4% deviation max is a good rule.
The real issue he is having is trying to stay in the same rim size.
Wolfman,
I've been taught by the best engineers in the industry that 2% is the golden rule you have to play with when it comes to the tire size/ratio differences.
And in figuring it this way I've never encountered a problem whether it was a B7100 Kubota or Case/IH8930 zero problems when the changes were done.
If you know something different please enlighten me of the particulars as I do this quite often making a living selling tires.
Al
9,377
Wolfman,
Al
That's only a very slight deviation that's only 1% larger and 1% smaller.
In real world settings your going to have more deviation than that just in normal tire wear right.
While I'm not disagreeing with your thinking, I think 2% larger and 2% smaller if a much easier number to achieve. ;)
Heirbornranger
B7100
Jul 10, 2015
Ar
Could you post a pic of a side view on that set up in thinking of purchasing that set up but I'm interested in how they size up with the tractor
