The switch I plan on using for some ROPS lights (2 x 36w LEDs) has a 3 Amp 125 v rating. By my calculations the switch should be good for 30 amps at 12 volts. Any issues I'm missing?
Yes. You are missing AC vs DC.The switch I plan on using for some ROPS lights (2 x 36w LEDs) has a 3 Amp 125 v rating. By my calculations the switch should be good for 30 amps at 12 volts. Any issues I'm missing?
Most multi-meters have a 10 amp DC current setting. Hook up some jumpers and see what the current actually is.Torch,
Thanks for the pointing that out. The lights suggest they will accept voltages as low as 9 and up to over 30 so I am not sure what their "actual" rating is.
If the voltages are the same. He's going from 120VAC rating to 12VDC so the current capacity goes up, just no where near as much as he thought.Switches handle LESS amperage with dc vs ac
An excellent alternative.Use a switch to switch a relay, and use the relay to power the lights!![]()
That would be fine. No problem running one of those light bars per switch.I have room for two switches - if each could handle one LED light
The 120v would be like psi on a hose.Riddle me this- if the nice orange illuminated led switch is rated for 125 volts, how will it work on a 12 volt circuit?
Am i missing something?
Bx,The 120v would be like psi on a hose.
So a hose rated at 120psi will work with 12 psi.
Some fuses are marked for 240v but work on lower.
The switch may work to power the circuit but I believe the question was how the light in the illuminated switch rated for 120v AC could be powered by 12v DC.The 120v would be like psi on a hose.
Andy,Regards the LED light, I did a workbench test to se if my planned wiring would work out and the system works fine (LED lights, switch works a test light, relay kicks in when it's supposed to). The issue I guess I am stuck with is the capacity of the switch to the ROPS light I had planned to use.
So if I plugged in the switch and it failed, I assume it would just quit - or is it a fire hazard?
BTW The site I bought these switches off seemed like it was targeted to 12v automotive use even if the rating on the switch is listed AC.
