SVL 95-2 error code
trooper632
m126gx, m108s, m96, svl-95-2
Nov 10, 2019
15
Sabinal, texas
Working the machine and the error code and warning showed up, with reduced power. Service code was 9502 air in fuel system. book says could be low fuel if not call dealer. Almost full tank on machine. I turned off machine and checked engine compartment, everything looked fine no fuel leaks anywhere. Started machine up again and ran fine for about 10 minutes and then same code. Repeated this process about 4 times before I finished. Any one else had this code before. Could be just computer issue but its out of warranty and I know Kubota will charge an arm and a leg just to diagnose it. 2017 machine with 350 hours on it.
whitetiger
Nov 20, 2011
2,593
1,105
Kansas City, KS
E:9502 Diesel Exhaust Fluid Tank Level sensor error, not sure what book you are looking at.
Most commonly the DEF tank header has failed. Take it to your dealer, emissions would still be covered.
There are several PSB's on these units, have your dealer check to see that they have been completed.
trooper632
Nov 10, 2019
15
Sabinal, texas
NO already had that replaced. Looked up the code in the manual and it said what I posted
4,391
Trooper, you're trying to get the information needed so you don't have to take the machine to a dealer. You're getting the information the dealer would tell you, and you're not thankful, but reject it? I'm confused.
trooper632
Nov 10, 2019
15
Sabinal, texas
D2Cat I am always thankful for information and not rejecting anything. I got busy and hadn't checked back to my question, so here is an update. I was mistaken on this error code given it was 9302, air in fuel. I had the 9502 before so I guess I just had that stuck in my mind when I posted it excuse me. Replaced the spin on fuel filter and fixed the codes and low power limp mode.
1,003
You may want to treat the fuel with algaecide if you think that may be why the filter has clogged.
Check fuel for water/black slimy bits to see if you have a problem.
hodge
Nov 19, 2010
2,854
367
Love, VA
Treat it anyways. Keep it from forming.
whitetiger
Nov 20, 2011
2,593
1,105
Kansas City, KS
E:9302 = Fuel Leak (High-Pressure Fuel System)
The code is usually set off by low fuel pressure caused by a partly plugged fuel filter or debris in the supply hose to the Water Separator. When the Common Rail Fuel pressure drops below a preset threshold, the ACU will derate the engine.
