Steering wheel wont stay centered
Mainiac
Lx4020
May 3, 2026
Maine
Every time I use my lx4020 the steering wheel is ends up in a different position. I have a spinner knobs positioned at nine o'clock when going straight but after using the tractor it ends up somewhere else. Is this normal?
lynnmor
B2601-1
May 3, 2021
1,823
1,624
Red Lion
If a tractor with this type of steering is parked the same way with the steering wheel in a certain position, will that take care of the problem?
6,879
Kubota’s website indicates the LX4020 has “hydraulic power steering”. Assuming that is correct, yes your experience is normal. IMG_8736.png
Kennyd4110
Vendor Member
Sep 7, 2013
1,527
910
Westminster, MD
www.boltonhooks.com
No. You just have to get used to it...it's just one reason I don't like 'spinners' on my tractor.
If the orbital valve has some leakyby, you can even see the wheel change position slowly while drive straight down the road.
7,717
I image the steering function is a real nightmare for folks with OCD or anal about everything! Nothing can be done to change it, except to abandon it.
nbryan
Jan 3, 2019
1,438
951
Hadashville, Manitoba, Canada
If you steer hard left or right to the limit of the wheels stops, and maintain steering wheel pressure against the stop, the hydraulic steering cylinder has an over-pressure release valve in its circuit that allows the steering wheel to continue rotating past the initial stop, which changes the wheels' relationship to the steering wheel position.
Grandad4
Apr 5, 2016
446
195
Greensboro, NC
Both of my Kubota tractors had spinners. Sure they drifted a bit but they were very handy regardless for loader work, mowing, etc. The hydrostatic power steering prevented kickbacks that were the curse of having a spinner on old-school tractors back in the day.
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
98
50
PA
Never knew it. But a few days ago, I did notice wheel difference.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
When I went from a tractor with power steering to hydraulic steering it bothered me for at first. After some seat time it isn't an issue. I do have a suicide knob and use it a lot because of the frequent turns while mowing or using the loader/snowplow. While mowing longer stretches, I usually rest a finger or two on the wheel.
