Squeaky front wheel
Bill8200
B8200
Oct 12, 2020
35
PA
In this cold weather, my front wheel has been squeaking until it warms up. Is a bearing the only thing that could squeak on a B8200?
2,897
You have FEL on that tractor? Curl the bucket - rotate the wheel by hand once off the ground and see if you can pinpoint the sound
Have you check the fluid level on the front end recently ?
Bill8200
B8200
Oct 12, 2020
35
PA
I will check wheel using your suggestion. That’s a good idea. I check the front end once a year or so. It’s probably good but I will check again.
3,288
In my mind a bad bearing would not get better with heat resulting from use.
My gut tells me it is likely a stiff seal that is causing the squeak, but also low oil level could contribute. So I would naturally check oil level. Thinking that as it warmed up, the seal would become more flexible.
If you are using normal gear oil in the front axle, instead of UDT or SUDT, perhaps changing to UDT or SUDT might help the issue, if it is related to lack of lubrication of a seal due to cold temperatures, when thicker oil would be less likely to lubricate the seals until it warmed up a bit.
Just a novice thinking out loud here...
Bill8200
B8200
Oct 12, 2020
35
PA
Just using 90 weight. I’ll check into it though. Thanks!
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Torque the wheel nuts… and look closely for cracks while you’re there.
3,682
Front axle support greased?
