SPL0560 Snow Pusher: will it attach to B2601 SSQA?
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/BX2812APlow/WC-68 Chipper
Sep 24, 2012
403
299
right coast
The manual for this Snow Pusher states that it needs to be used with a '...Kubota BX front loader with or without BX6315 Quick Hitch'.
I'm wondering if this SPL0560 will attach to my B2601 loader quick attach (SSQA) system. Are there any B2601 owners currently using this setup?
I've tried to find documentation addressing this fit but thus far have come up empty, thought I'd try this forum and see if there any users with experience. Thanks in advance for any info! :) (y)
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
364
158
Southern Worcester County, MA
It will fit with no issues. As far as I know those have no issue between the BX and B series. Its once you start getting into the larger machines you could possibly damage it as it's not as heavy duty.
jkrubi12
Sep 24, 2012
403
299
right coast
Thanks for the info; I finally found a vid on u-tube where a member was using one on a B2301, so I'm pretty sure it'll fit on my B2601. (y)
8,621
A SPL0560 will not work on an SSQA equipped loader unless it comes with the adapter plates, it's originally designed for a completely different BX mounting system!
5,604
this may shed some light...
picture on the right shows 2 black ADAPTERS needed to convert to SSQA
they look simple to build but wonder what they cost .....
jkrubi12
Sep 24, 2012
403
299
right coast
Thanks for the replies; the need for 'adapter plates' is correct, the one I looked at already had those adapters attached! :)
WAS BANNED FOR NSFW PICS
5,151
I wonder how well they work on the BX tractors because I know that there have been times that I can't move the snow in front of my plow blade without pushing it off to the side every 20' or so, since the snow is so heavy. This is why a snowblower is the best answer for my situation of moving the snow off of my very long driveway. After I get the driveway cleaned of snow, I go back over it with my snow plow to get down to the bare pavement, so there is no ice forming on the driveway to cause vehicular issues.
BAP
Dec 31, 2012
2,903
1,018
Are you looking at the one that is for sale on the local Facebook Marketplace in NH?
jkrubi12
Sep 24, 2012
403
299
right coast
Keep posting @DustyRusty, I've learned more about Kubota snowblowers from reading your posts than I have in my own research! (y) :)
jkrubi12
Sep 24, 2012
403
299
right coast
Yes; looked nice but after watching some videos I've decided to stick with my current (22 years & running) setup.
The videos I've seen make snow removal with a tractor seem labor intensive; a front-mount snowblower would be awesome for large dumps, but my snow removal needs are more commonly frequent light accumulation cleanup. :)
BAP
Dec 31, 2012
2,903
1,018
What are you using now that you are going to stick with using?
jkrubi12
Sep 24, 2012
403
299
right coast
Snowplow, snowblower & shovel :)
dieselbob69
Kubota BX2380 (previously a BX1870 and GR2100)...
Jan 2, 2022
159
61
WNY
I have the SPL0560 with backdrag on my 2380 with R14T tires and ballast box. The storm we had mid-November was first time I really had to use it. First time was 10-12", mostly powdery type snow. I'd say it easily cut my time in 1/2 over the 48" bucket. As far as heavy wet snow, haven't had that yet, so we'll find out. If it's too much for the pusher, that's why I have a Honda HS1132 track drive snowblower as backup (y)
