Slow poke
3,231
uhhh, gonna need more details than that.
engine rpm up? brake on? low/high range? dragging something? rock caught in rim??? Flat tire? Air and fuel filter clean?
etc
You have to help us help you.
5,129
Do you have a BX25 or as your listed equipment shows a BX24?
And yes please give more details.
Note: This thread is being moved out of the sale thread to service. ;)
lugbolt
ZG127S-54
Oct 15, 2015
4,843
1,598
Mid, South, USA
Look at your HST linkages. Follow the rod from the pedal link back to the transmission. Right there at the transmission's trunion arm, there is a ball joint, the rod is threaded into it on the front end, and the other end that goes through the trunion arm has a nut on it. 5/16-24 as I recall. Well they didn't put lock nuts on them. Just a nut and lock washer, and they sometimes come loose/fall off.
.....this is assuming that you're talking about the HST being slow, yet engine runs perfect.
