Hello! I recently bought a 1994 Kubota L4350 with Hydraulic Shuttle and Everclutch. It runs and operates well, except for one thing. The hydraulic shuttle lever is sloppy when put into forward gear. When put into reverse, the lever "clicks" into place and reverse gears work as expected. The lever stays in reverse position like it should. When put into forward position, there is no "click" feeling and the lever slides back to neutral very easily. The linkage going down the left floor follows suite. The tractor sometimes hesitates in forward gear and feels like the clutch is staying engaged longer or more than it should. Is there an adjustment I can make? Either on the column or with the linkage? Or the clutch itself? I am in New Hampshire and waiting on the snow to melt to be able to tinker with it for any length of time. Thanks for any replies.
