Sloppy shuttle shift
J2thesea
1994 Kubota L4350DT LA 950A Loader Woods BH90X Backhoe -1979 Kubota B6100
Feb 12, 2025
14
Salem, NH
Hello! I recently bought a 1994 Kubota L4350 with Hydraulic Shuttle and Everclutch. It runs and operates well, except for one thing. The hydraulic shuttle lever is sloppy when put into forward gear. When put into reverse, the lever "clicks" into place and reverse gears work as expected. The lever stays in reverse position like it should. When put into forward position, there is no "click" feeling and the lever slides back to neutral very easily. The linkage going down the left floor follows suite. The tractor sometimes hesitates in forward gear and feels like the clutch is staying engaged longer or more than it should. Is there an adjustment I can make? Either on the column or with the linkage? Or the clutch itself? I am in New Hampshire and waiting on the snow to melt to be able to tinker with it for any length of time. Thanks for any replies.
10,841
Lets clear something up, they never made the L4350 in and EC (ever clutch) and be thankful you don't have it as you can not get parts for it.
Give me your serial number so I can see better which linkage it is equipped with for the shuttle.
J2thesea
Feb 12, 2025
14
Salem, NH
I’ve seen this said in many places! Ive included a pic of the side of the tractor for reference. Maybe someone added the sticker. lol The serial number is 60270. Thanks for the response!
10,841
Ok I'm going to eat a little crow on this, it does have an EC but it's not the same as all the rest of the EC's out there.
The normal EC had it in the Bell Housing and was prone to going out.
This model has a dual EC in the transmission.
What they now refer to it as a shuttle clutch.
Now to confirm which exact setup you have.
You'll have to look at the clutch linkage to figure out which one is right:
You should have HDT-W
First clutch lever MDT and HDT look like this.
Clutch lever HDT-W will look like this:
Clutch pedal MDT and HDT
HDT-W clutch pedal
J2thesea
Feb 12, 2025
14
Salem, NH
No need to eat any such bird. You have far more experience and knowledge than I. And you have solved the mystery of the everclutch in the L4350. A bit of knowledge I would have NEVER known otherwise. I will check the linkages and report back with my findings. Thanks again!
10,841
Really if it has the flat clutch pedal that says it all.
J2thesea
Feb 12, 2025
14
Salem, NH
True. I was putting the toddler down as I was looking at those. It has the hydraulic shuttle shift and it definitely has the flat pedal clutch
10,841
Ok for the shuttle slop
Check these ball joints (yellow) they are the most common to wear and cause engagement issues.
Again check these ball joints (yellow).
Check for excessive wear on the pins and loose linkage bolts (blue).
Also make sure the spring (green) is in place.
J2thesea
Feb 12, 2025
14
Salem, NH
Awesome! Thank you. When the weather breaks a bit I will get out there and check it out. It’s good to know what to look for. 👍🏼✌🏼
