The simple front weight design in my earlier thread worked but the front end was still not firmly placed on the ground with a heavy back load.
I went to the local iron merchant and bought two pieces of steel 400 mm long and 100 mm square each with a weight of 32 kilo (about 70 pound).
Welded a 180 mm long bit of L-shaped steel to the side as you can se below.
The other got the same steel on each corner sticking down 70 mm. Then a piece of rebar as handle to place it on the first weight. Hopefully 64 kilo is enought.
I have not painted it orange yet.
Anders
Anders
