Sharpening Brush Hog
johnjk
Apr 13, 2017
1,753
2,068
West Mansfield, OH
I was told by my Kubota dealer to also not bring them to a sharp point but rather leave the edge rounded off like a #2 pencil. If you put a sharp edge on it, then it will get beat up and ruined going through heave stuff, saplings, stumps, ant mounds (my favorite)etc...
I have not looked at removing them from my Woods brush hog, but need to get on them this spring. I may try leaning it against a tree and hitting it with an angle grinder
Stmar
B2650HSDC
May 23, 2017
945
57
Buffalo, Wyoming
Take the blades off and sharpen them with a flap disc on a 7” grinder.
I have tried to take the blades off with no success. Asked the Kubota guy how they did it and he said they just tilted it and used a hand grinder so that is the way I did it. It would be nice to get those blades off, may do the heat and impact deal if I have some spare time. I was afraid I did not get them sharp enough but according to the other poster I think I got them just right.
russell.still.5
197
Lafayette, Alabama
If you get them sharp like a lawn mower blade, it can cut sapling off and they will be sharp enough to puncture a tire. A blunt edge will “shatter” the stump so it won’t be sharp.
I have heard that woods blades are easy to remove. It’s a small bolt through a retaining clip which hold the “blade bolt” in.
I have tried to sharpen blades while on the cutter and i can’t get the grinder in a satisfactory position to really sharpen them.
Newlyme
M4900 w/loader, finish mower, tiller, auger, rake. BX24 w/loader, backhoe
May 27, 2015
628
74
Nelson Ohio USA
Next time you are at the dealer, Tractor Supply, or similar place take a look at a new blade and sharpen it similarly. ;)
Nothing like seeing it first hand.
3,014
Believe it or not.....crawling under and getting it done is about the only answer!!!
Getting those nuts off requires a butt load of torque and I tried many years ago! 1 1/4 socket and a 8' cheater bar!!!!! Nuttin!
Make sure the cutter is in a safe situation and get a 4" grinder and hit those edges......
and as others have said.....sharp IS a bad thing......you want a dull edge across, unless grass is THE ONLY thing being cut, which is not often the case, a dull even edge will cut up "stuff" and not leave sharp edges on branches and IF you hit a rock, it will not take a huge chunk out of the blade.;)
SDT
Apr 15, 2018
3,582
1,329
How do you sharpen the bladesign on your brush hog?
Unlike most, I keep the blades on all 4 of my rough cut mowers sharp lake a lawn mower. Cut is better, mower takes less HP and tractors use less fuel.
Yes, my ground is clean and I do not hit rocks, dirt, etc., or cut saplings.
I simply reach under the raised mowers with a 4.5" angle grinder. When installing new blades, I sharpen before installation. I touch up blades after each use.
Sharp blades are not recommended if cutting saplings as cleanly cut saplings are much more likely to puncture tires than are saplings shattered with dull blades.
SDT
2,813
To remove the blades there is normally a hole with a cover on top of the deck. Take off cover and rotate by hand the blades or stump jumper until you see the nut.
Get a (3/4 drive) heavy wall socket and extension and a breaker bar. See if you can get them loose by hand. If not then rig a small come along to the three point structure on the mower and the breaker bar and make sure you have it turning the correct direction to loosen the nut. Break it loose with the come-along.
Or go to Northern Tool and order the torque multiplier for around 250 dollars and use that. You can use that along with a torque wrench to replace the blades and torque the nuts.
5,020
If those nuts are on there, that bloody tight,,, they are going to stay on there, that bloody tight
CapnDean
L6060,ZD1211
Feb 22, 2018
183
Gulfport, MS USA
I take mine off with an impact. In the past I have used Heat and Kroll oil to get em loose the first time. I also use anti-seize compound when I put em back on.
markchief
12
East Windsor CT USA
I pick it up with the FEL, grinder the rough stuff off, then sharpen with die grinder & 40 grit pads for grass,etc. For heavy cutting (brush up to 3") just the grinder. If that stick in the picture slips, we'll assume you quit the forum!
Sent from my SM-G955U using Tapatalk
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
The ones on my Hog were frozen. It took several days of applying 50/50 acetone/ATF mixture and hitting it with an impact gun till they gave up and came off.
