Sharpening blades
4,082
This may not be the best place to put this,, but has any of our really smart guys in here cume up with some kind of a jig the would hold the blades at the right angle so they can be sharpend with a grinder,,, when I sharpen blades,,,, well they aint pretty so Im looking for some kind of a jig,,, here ya go guys a money makin deal!!
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
Skeets what kind of grinder do you use bench or side. I use bench never used jig and it is a trick to it. ;)Most people round ends off without even knowing it until they leave that one strip of grass in the center of 2 or 3 blades. Tell me if you use a bench grinder.handy
4,082
Yeah I have an old Baldor bench grinder and an angle grinder too,, When I do it they never quite look the same again,,lol.. What i was thinking was something that would hold the blade so you could grind across it at a 90 and the jig would already have it tilted to the right angle,,, any hints are always welcome
Sam427
L3410 GST, FEL, Bush Hog, Box Scrape, Spreader
Nov 6, 2009
194
Snellville, Ga. USA
You might attach a magnetic protractor to the head of your angle grinder to get the proper angle? I'm a machinist, so it's just second nature to me.:D Always helps to have a fresh rock on the grinder, when they get rounded off it makes it harder to maintain a certain angle.
Make sure they are balanced, otherwise they will vibrate.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I clamp mine in a vise and use a die grinder to sharpen them. A flap wheel or a surphase prep pad seems to work just fine and doesn't eat the blades up at all. It is easy to keep the edge at the right angle to.
Will In Tx
L3400 HST/FEL, Box Blade, RTV 900 Camo, ZD323 Zreo Turn Pro Mower + More
Mar 21, 2010
303
Rosharon, TX. USA
Could come up with a metal holder welded together but you need a angle finder which is about $8.99 at Lowes or Home Depot.
Check what degree it is with it.
Just would have to set back and make a ruff sketch.
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
;)eserv I have to say you are a honest man from your answer and I DO NOT mean any disrespect at all. handy
Orange in WI
L3130 with loader-BX2360 with Loader,front mount snowblower,60MMM
Jun 16, 2010
10
Fond du Lac,WI USA
I use a bench top belt sander. Have two of them one three inch wide and a one inch wide, Been using these for years. Don't use a grinder any more at all.
