I ordered a skidsteer attachment from Shandong Brothers Industries LDT located in china (Hong Kong). As of 8/1/23, because of poor/ and NO communication from Brothers, I could only assume that they never shipped the product. I figured that I lost lost $5,445.00 (total cost of Compactor/Shipping/US Customs). It arrived more than 10 months later.
The salesman just kept telling me that my product is on its way. When I ask him for the necessary shipping and port of entry documents, he says he will send them, but then never produced the actual documents. Emailed the management and owner, they did not respond. Contacted the China bank who did the wire transfer with my bank, they would not respond (finally denied my refund claim).
There isn't an avenue or conduit for Americans to investigate or get a refund of their money.
If you order through Alibaba, you should get "Trade Assurance", but be careful. Before transferring money, to seller; contact Alibaba and be sure the seller submitted Trade Assurance documentation. Read your Trade Assurance very carefully and thoroughly. The seller sent me the Trade Assurance document, so I thought I had it, but the seller never submitted to it Alibaba, therefore Alibaba denied my claim. All communication from Brothers has stopped.
UpDate 12/29/23
On October 20 2013 I received a phone call from the importer telling me that I have a crate that arrived from China. It was the sheep's foot compactor. This unit was ordered in January and arrived on October 10-2023.
Today 12/29/23, I had a chance to unpack the unit. The unit was in an heavy duty angle iron case. Unpacking was easy. The steel crate was large enough so all I had to do was hook a chain to the compactor, cut the retaining wires that were holding the compactor in the crate, and using an excavator, I lifted the compactor out of the steel crate. Note: I purchased a smooth compactor from Mower King and the steel crate had to be cut completely open to remove the compactor.
The compactor hitch plate connected quickly and easily to my Kubota SVL-95-2 hitch. The mower King compactor would not connect to a Kubota SVL95-2. I have to make significant modification tot he Mower King Compactor in order for it to hitch properly.
The next surprise was that the quick connect hydraulic couplings were already mounted to hoses. Mower king does not supply hydraulic coupling with their attachments ($270). The hoses were the correct length so whereas they did not rub on the vibrating drum (unlike Mower King). The hoses were also double wrapped to prevent any wear from the vibrating motion. Mower King did not have the hoses cut to the correct size and the edge of the compactor quickly cut through one of the hoses. I greased the compactor very liberally before running it. There are two grease fittings one on each side.
I had my hydraulic setting on "LOW FLOW", outfeed on #5 and return on #5. I ran the machine at 1/3 throttle. The pad-foot compactor seemed to work as it should. I used to for approximately 10 minutes. I didn't experience any smoking or over heating as I did with the Mower King Model which burned up the bearings up within 3 minutes. it appeared to compact as it should.
In the next month, I have two shop "pad" jobs on my schedule. I will update this after I have finished both jobs.
UpDate 12/29/23
