sagging bucket
KevinP
Kubota L4400; Loader LA703
Jun 9, 2019
Festus, MO USA
I have a Kubota L4400 with a LA703 front loader. The rock bucket on the front end of my loader sags / drops, even when empty. Hydraulics are strong on 3 point lift. Any advice? thanks for your help. -KevinP
Jblac197
L3800, bush hog, tiller snowblower
Aug 21, 2018
73
Hibbing
Bypass somewhere. Could be the cylinders, could be the control valve.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
SidecarFlip
Banned
563
Some do, some don't depends on the valving and how well they seat. My older M (2004) has no drop what so ever and my newer M (2006) drops and has dropped since new.
I ignore it. It don't impact function at all. Good reason to set the bucket on the ground when not using the machine anyway.
11,377
If I'm understanding what your saying, most likely you have bad internal seals in the one or both of the roll cylinders. ;)
KevinP
Jun 9, 2019
Festus, MO USA
I can't really ignore it. when I'm using the bucket, I have to keep rolling it up so I don't lose my load.
KevinP
Jun 9, 2019
Festus, MO USA
Thank you. That makes sense to me as the bucket will hold its height, just rolls down. And the 3pt hitch is strong. Are the internal seals replaceable / fixable or need to purchase new roll cylinders? thanks a million!
7,738
You can remove the cylinders and take them to a hydraulic repair shop. They can disassemble the cyl and rebuild them. They will have access to the parts needed.
