Safety switch dilemma....
KB3030
Benton, PA, USA
I have a B3030, it has just started blowing the 7.5 amp fuse.(Which with everything read, it sounds like it should have been a 5 amp)
I can start the tractor without being on it. I tested both seat switches with an ohm meter and they checked okay. I started the tractor, engaged the PTO, stood up and the tractor shut off, so I presume that that safety switch is operating normal. I don't see a safety switch on the F/R foot pedal, but I can make the tractor move while standing next to it and pressing the pedal.
Is my problem in a relay? How do I find it?
9,237
Your question leaves too many holes:
What fuse is blowing?
What does that fuse control?
What are you doing to make it blow?
Just a quick pursing of the WSM I don't see any 5amp or 7.5 amp fuses the smallest I see is a 10amp.
There is a Safety switch on the HST unit or pedal assembly that controls that portion of the system.
Also is it a Cabbed model or a ROPS model?
KB3030
Benton, PA, USA
It is a 7.5 amp fuse, the very top one in the box. I do not know what this fuse controls, as there is no markings on the fuse box to tell me which one does what. There is not even a fuse box cover.
I was driving the tractor plowing snow, using the bucket as I do not have the money to purchase a plow blade yet.
ROPS model
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
ROPS model
The 5 amp fuse powers the OPC system here is an outline of how it works
KB3030
Benton, PA, USA
Thanks for the diagram.
I have removed the fender on the HST side and think I found where the safety switch is. I'm in the process of trying to figure out how to remove it and test it.
I am still puzzled as to why can I start the tractor without being on it? I thought the seat switches was suppose to prevent that? I checked continuity across each switch and they tested okay. All wiring appears original.
