Rotary Cutter for MX5100
BigG
Sep 14, 2018
1,951
773
West Central,FL
The hydraulic top link will still limit the amount of flex between the mower and the tractor. The old school method is to replace the top link with a short piece of chain. This allows you to pick up the mower quickly and prevent damage to the top link if the rear tires of the tractor drop into a hole or as you cross a ditch.
Shanester
B7500HST MX5100HST
Sep 21, 2021
77
34
I have read about that idea and would prevent damage but it would still allow the wheel to come off the ground when going over a hill . It happens all the time. Maybe there is no fix for this. I'm going to try to get the rocks out and think there's only a dozen or so.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,248
1,869
WestTn/NoMs
Sometimes the wheel will come off the ground when you go over a rise.
The real damage you want to avoid is bending the top link when you cross a ditch or swale. That tends to shorten the distance and put the top link in compression.
I've never used the chain approach, but I like the idea. Just have to make sure it can't get in the drive shaft.
Shanester
B7500HST MX5100HST
Sep 21, 2021
77
34
I got it all set up the best I could yesterday. (there is no flat spot on the ground to measure from) Also I did not get the pto shaft safety chains with it so I had to make some. If I remember correctly there are 7 holes for the rear wheel adjustment and I put the bolt in the middle hole. I'm estimating that I'm cutting about 5" tall. I tried it out for about 20 minutes and it cut great compared to the 4' cutter on the little 1025R. I was climbing large hills in the middle hydro range cutting really thick and tall stuff (has not been cut in years) and the RPMs only dropped about 200 or so. The 1025R would REALLY struggle with that even at a slow crawl. Needless to say I'm very happy with the way it mows. It still only lifts the mower less than a foot off the ground with my adjustments. I'm starting to think about the chain idea instead of top ink again and I will try to explain my concept the best I can. Make the chain length have enough slack in it so it lifts up about what it does now. Maybe a little less. Say it lifts the wheel about 10" on level ground. That should be enough lift height to get me off a log or rock quickly while mowing. If the chain has enough slack that it interferes with the PTO shaft then I could put a bungee cord from the middle to the tractor somewhere pulling it upwards. If the chain size was large enough for a pin to go through the links then I could lower the mower all the way down and re-adjust the length quickly in the field after I'm done mowing. That way the rear wheel won't occasionally bang on the ground plus I can get under it for maintenance or pulling out wire and such.
jyoutz
Jan 14, 2019
3,380
2,422
Edgewood, New Mexico
I am leaning towards a middle of the road 6'er. One with 2" cutting capacity so it should not be too heavy. I have found some that have chains in the front, chains in the front and rear and ones with no chains. Of course no chains are less money. The 4'er that I was using had chains front and rear. How important are chains? Can they be added if I can't find one with chains? They look like a bolt on kit. Woods charges about a total of $300 more for both front and rear chains. If buying a new cutter should I be looking at another brand besides Woods or Land Pride? Bush Hog brand?
I’m buying a MX6000 and decided on a landpride RCR2072
SDT
multiple and various
Apr 15, 2018
3,311
1,102
SE, IN
Good choice.
I use a Woods BB720X, 6' cutter with my L6060 and, cutting close as I do, it's all it wants.
SDT
jyoutz
Jan 14, 2019
3,380
2,422
I found a used Land Pride RCF2072 for $2,200 that looks in okay shape but it missing the front and rear guards or chains.
I’m buying that same cutter new with my mx6000 purchase. It sells new for $3200. The chain guards are an option and do not com with the cutter.
jyoutz
Jan 14, 2019
3,380
2,422
jyoutz
Jan 14, 2019
3,380
2,422
Most newer cutters have a flex link built into the top link connector.
SDT
Apr 15, 2018
3,311
1,102
SE, IN
Agreed, but such linkages have limited operating ranges which are usually (always?) inadequate for uneven terrain.
SDT
jyoutz
Jan 14, 2019
3,380
2,422
SDT
The flex link has always worked for my needs, but I don’t do cutting on hilly terrain.
