Removing tierod pin from pittman arm on L3400?
cjmssmd
L3400HST
Apr 27, 2014
Sandy Spring, MD
I have a 2005 L3400HST. I just bought it last week.
See the steering linkage part diagram at https://drive.google.com/file/d/0B7Vvx74a-airRFpMdHhaQjZxSk0/edit?usp=sharing
The right tierod inboard tierod end (the end closer to the pittman arm) broke. The ball and socket separated. I can't get the pin (threaded on one end and with a round metal ball on the other end) out of the pittman arm. I removed the nut but need to know if I should just pull really hard, or if the pin itself is threaded?
On page 2 you see the diagram I'm talking about. Part 140 is the right tierod pin assembly and it is what broke. I removed the nut (#150) but can't pull the pin out (down) of the pittman arm.
Any suggestions?
Thank you
Chris
kubotasam
Apr 26, 2010
1,210
132
Alfred Maine
It is a taper fit down into the pitman arm. You need a tie rod end fork to wedge it back out. You put this in between the ball and the pitman arm then hit it with a hammer.
8,723
That fine tool is called a pickling fork, if you don't want to buy one, most automotive stores will loan you one.
They are not that expensive to buy and tools are always a good investment!
cjmssmd
L3400HST
Apr 27, 2014
Sandy Spring, MD
Got the pickling fork and hit it with a 5lb hammer, pretty hard, but the tierod end pin didn't budge. The pitman arm is still on the tractor and I don't want to break anything else. Should I really whack at it until the tierod end pin comes loose?
(The second picture may give the impression that the pickling fork wasn't fully forward and seated - but - it was - just not when I shot that picture).
aeblank
411
Cadillac, MI
I beat the piss out of mine doing tie rod ends (on a silly car, but still). Wouldn't surprise me if it takes quite a bit to break it loose.
Sent from my DROID RAZR using Tapatalk
8,723
In the second picture, will the fork touch the ball and the pitman arm?
In the picture it has a gap, if it does it's not going to work right, it has to wedge between the pitman arm and the ball.
You could use a pitman Arm puller or a very large gear puller.
Sorry I would have said pitman arm puller in the beginning if I had seen a picture first of what you had going on.
8,723
If that's the case up the hammer size and whack it hard! ;)
