remove blades from mid mount mower?
Rob 80
B2650 HSD
May 9, 2016
39
WVA
It's almost time to replace my mower blades, i have a 60" deck model rck60-30ba.
If the grass ever stops growing i will take it off and replace them it hasn't been cutting very well lately.
Is the bolt that holds them on turn counter clockwise to loosen? or is it backwards.
BTW does anyone know what size bolt holds them on?
BillK01
BX2360, FEL, LP 1560 back blade, Front mount snow blower, Ferris ISX800 ZTR
Mar 17, 2017
169
Near Pittsburgh, PA
My RCK54P23BX mmm is standard thread and 30mm. Hopefully that is some help.
2,191
Get an impact if you do not have one .....dont need it per say but it will help BIG time!
2,852
And torque wrench too,, yes I am thinking its 30mm remember laying under the deck,,, AFTER you have the tractor jacked up and blocked and brakes set. and the deck all the way up.. It's righty tighty lefty loosy..
NOW when you take the bolt out watch,because there is a set of belleville washers they look to be a flat washer but in fact they do a have a case to them almost like a spring a little cup if you will,, dont flip them around,,,, dont ask :( ... I dont have my book at hand but Im thinking the torque range is 75 to 90 foot pounds. You can go with a grunt and a half if you dont have a torque wrench
Dont forget that hunk of 2x4 to wedge the blade when you take it off and put it back on. Use something like neverseze on the bolts when you put them back in. This is also a good time to grease all the bearings on the deck.
It aint rocket science just think it through first and try to figure what could happen,,,, cause it probably will sometime or another :D
Rob 80
B2650 HSD
May 9, 2016
39
WVA
30mm i don't think i even have a socket that big, i do have a impact driver i use it to take off wheel lug nuts but sometimes it dose not work.
2,191
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
X2. I got tired of cheater bars and busted up knuckles and got a medium sized compressor and air tools.
Rob 80
B2650 HSD
May 9, 2016
39
WVA
I have a dewalt 20v model DCF887B impact driver it's little and probably not enough torque for a 30mm bolt it does get my wheel lug nuts off but i have been looking at it's bigger brother the DCF899B.
I use it to put long screws in my deck it works better than a normal drill.
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
And if you are over 50 take two aspirin or Tylenol before you crawl under the deck. You are gonna be sore later on! It is called a pre-emptive strike! .....:)
Rob 80
B2650 HSD
May 9, 2016
39
WVA
HA HA i'm in my 40's and am already sore after crawling around on the floor :eek:
I actually take the mower deck off and use the loader to flip it up side down to clean up. That thing is a beast to handle by yourself almost 400 lbs of mower.
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I must really be lazy, I use the loader to lift it on end, and high enough I don't have to bend over.
Sent from my LGMP260 using Tapatalk
4,415
Boz1989, that's the benefit of have a loader on a tractor you're not working on.
When I need to work on the deck of the B7100 I just pick up the front of the tractor after is deck is disconnected and pull it out.
2,191
Something like this???:D:D;)
2,852
Awwww comon guys I dont want to go look at a new one,, well I do, but I dont, but I,,,,,, you understand
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
Yea... those impact drivers are a great tool! I have the socket adapters for mine, but I have yet to try it on anything large.
2,191
85Hokie, you displayed that nicely. Now if anyone needs a reason to have another tractor...here it is!!:D
Well the reason that picture was taken......
I ran the B7100 a smidge to close to a 12' tarp laying near by.....sucked that thing up like a vacuum cleaner.....
I had to take the deck OFF and flip and cut the @#$%@%^@ tarp off.....
And that's my story .....sticking to it, much like that tarp to those blades!:eek:
