rear work light M100 X Oval shaped
ShaunBlake
B6100D; B219; Piranha bar; Hodge stabilizers; Filled Ag rears; R322T w/48" deck
Dec 21, 2014
899
Sugar Hill -- next door to Buford, GA
Hi, Louis; welcome to the forum!
I'm not sure what you want. Are you looking for lights to illuminate the inside of your cab, or lights to mount on the cab to light up the area behind your tractor?
Interior lights I don't know about. Exterior lights, "everyone" is installing LED lights because they require very little amperage (amps) for a LOT of light (lumens). That lets us add some additional lights without having to worry if our alternators or dynamos will handle the load.
Most of the work lights that provide substantial nighttime illumination are 18 Watts or greater. Sadly, not all LED light measurements are the same; often one 18-Watt light is much brighter than another, and some 10-Watt (or even lower wattage) lights provide adequate illumination.
You will find some valuable information by searching some of the posts in the forum and reading about other folks' installations. On the other hand, if you just want to buy something and install it in hopes it will be adequate, then it seems that 18 Watts is a fairly "safe" threshold.
Please keep us informed of your progress!
2,801
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
The adds on the left side of the page has some factory Kubota lights for sale. I would look at LED lights like the others said. I've been thinking about going with a light bar instead of single lights.
