Rear tire question.........
mrcj001
9
ky
My B1750 2WD has 9.5-16 rear tires.......Will 8-16 tires fit the rim
the reason I ask there is a $75.00 per tire price difference between the two sizes.
2,863
As long as you get the right RIM size....you can place almost anything on it!:D;) YOUR 2wd drive needs not any magical rolling circumference math.
And if you fill them - the amounts are roughly the same :
8-16 11.7 gal
9.5-16 12 gal
http://www.rimguard.biz/wp-content/uploads/2014/04/Hydro-Flation-tables-2014-PDF.pdf
mrcj001
9
ky
Looking in the owners manual, it wasn't clear that there was a alternative "rim" width......
The cost difference is $150 for the set with the 8-16 VS the 9.5-16
bucktail
Jun 13, 2016
1,274
195
MN
Does the tire manufacturer suggest a range of rim widths for the tire like they do for automotive tires?
