M mrcj001 New member Sep 25, 2015 9 0 0 ky Oct 10, 2016 #1 My B1750 2WD has 9.5-16 rear tires.......Will 8-16 tires fit the rim the reason I ask there is a $75.00 per tire price difference between the two sizes.
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 11,006 2,864 113 Bedford - VA Oct 10, 2016 #2 mrcj001 said: My B1750 2WD has 9.5-16 rear tires.......Will 8-16 tires fit the rim the reason I ask there is a $75.00 per tire price difference between the two sizes. Click to expand... As long as you get the right RIM size....you can place almost anything on it! YOUR 2wd drive needs not any magical rolling circumference math. And if you fill them - the amounts are roughly the same : 8-16 11.7 gal 9.5-16 12 gal http://www.rimguard.biz/wp-content/uploads/2014/04/Hydro-Flation-tables-2014-PDF.pdf
M mrcj001 New member Sep 25, 2015 9 0 0 ky Oct 10, 2016 #3 Looking in the owners manual, it wasn't clear that there was a alternative "rim" width...... The cost difference is $150 for the set with the 8-16 VS the 9.5-16
B bucktail Well-known member Equipment L1500DT, 6' king kutter back blade, boom, dirt scoop ford disk JD212 Jun 13, 2016 1,275 197 63 MN Oct 11, 2016 #4 Does the tire manufacturer suggest a range of rim widths for the tire like they do for automotive tires?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,979 9,178 113 Sandpoint, ID Oct 11, 2016 #5 bucktail said: Does the tire manufacturer suggest a range of rim widths for the tire like they do for automotive tires? Click to expand... Yes they do.
