Rear light install
jsobota
Kubota B6000 4WD
Aug 29, 2016
Germany
Hi.
I purchased a Kubota B6000 4WD and need to repair the front light socket and wiring (2 x 12V 15W lamps). Battery is 12V 45Ah. While at it, I thought why not add rear lights. There are several LED lights on sale, like this one http://www.ebay.com/itm/2pcs-18W-LE...ash=item43ce2aa1ad:g:AoAAAOSwFqJWoeyj&vxp=mtr
In total that would be 2 x 15W + 2 x 18 W = 66 W. However, I am not sure if this would not damage the battery, alternator or other parts.
Any advice is welcome.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
It looks like the B6000 has a 25amp dynamo, so that should be 320 watts maxed out. There is something about the early Kubota dynamo that escapes me at the moment... It may be that they only produce the rated power at high rpm, and very little at idle. Regardless, I don't think you will have a problem with adding the rear lights.
Rosher18
L185DT (1977)
Aug 2, 2016
Salem, Oregon
Thanks for the link to the good price LED pods!
In my experience, keep an eye on the cheaper products. A tiny 3 Watt LED will get very hot very quick, and sometimes the circuit boards aren't well thermally-bonded to the housing, and the heat will melt the solder joints, causing LED outages.
I'm hoping to do this to my ROPS soon, because it's quickly heading toward winter and I want to have lots of light when I'm working around dusk. :)
Sent from my VS986 using Tapatalk
jsobota
Kubota B6000 4WD
Aug 29, 2016
Germany
RJCorazza, many thanks for pointing out that to me. I will try to find information about that.
Rosher, thanks for the advice.
mdb6000
b6000
Oct 11, 2010
79
monroe, ct
my b6000 had a switch wired in from the previous owner for a back light, he did it the right way with fuses and relays(i think thats what its called), and i have a 55w flood light hooked up to it and it works awesome. Never had a problem
jsobota
Kubota B6000 4WD
Aug 29, 2016
Germany
Hi mdb6000
many thanks. Please, how goes the wiring that goes to the rear of the tractor? The previous owner passed the wiring through a protection tube?
torch
Jun 10, 2016
2,748
971
Muskoka, Ont.
Since you have to repair/replace the headlights, why not go LED there too? The total current draw of 3 or 4 LED lights could be less than the draw of the 2 original incandescents.
Caboose
B2650HST
Aug 16, 2016
80
Washington State
What is the lamp type and wattage of the headlights? I am a big LED fan and this would be one of the first "tweaks" I might be interested in doing.
Dean
