Quick attach problems
The B-man
L3301HST, LA525
Sep 6, 2021
Vermont
Hi, I have a new L3301HST with a LA525 loader (25 hours). I was using my bucket to clear some fallen trees and noticed that my bucket all of a sudden was hanging precariously. I lowered the bucket and attempted to reattach, but I’ve noticed that one of my two load arm attachment pads isn’t even with the other. I can’t for the life of me figure out how to get these arm/pads to become aligned. I cannot of course reattach my bucket.
Thanks,
Barry
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
One of the threads on here about your issue, not the same tractor but same problem. Couple other threads, search SSQA sync. Can’t offer much more help as I dont have one
torch
Jun 10, 2016
2,820
1,065
Muskoka, Ont.
There should be steel between them, which probably got twisted when the one side popped off. Remove the bucket completely and then curl back all the way until both hit the stops. That should align them. If one is springs back, you may need to put a block of wood between the stop and the more-curled side and then try again to "untwist" the steel joining them. Use caution and small movements in a trial-and-error approach to ensure you don't go too far.
ranger danger
Kubota M6060, MEB 802A tactically quiet generator
Jun 11, 2017
310
294
East of Placerville Ca
In a system where there are 2 hydraulic rams doing the same thing at the same the rams can get out of sync. Remove the bucket completely. Raise the fel about 2 feet. Then operate the curl function all the way BOTH WAYS 2 complete times. Then you should be back in sync. If not then do the same thing with the lift and lower function. It should all re-center itself.
