I have had this ongoing issue with my hydraulics. They have always been weak in my opinion.
I have a vintage L235DT it is equipped with the optional flange hydraulic block for additional outlets i.e loader. This is located under the seat on the left side of tractor.
The tractor came with a 1200 series loader on it with a 2 lever control valve set up. The loader valve was plumbed the following way. From the flange block I have a psi side and a return line. These lines went to the valve and then the 4 lines went out to the loader ( 2 boom 2 bucket).
When I purchased the tractor it was set up like this but the loader valve was leaking so I replaced it with a Brand Hydaulics single lever joystick valve.
The loader and the three point never really felt strong to me on this tractor. I cant even pick up a bucket of dirt after running it for a while.
So today I call the Brand Hydraulic tech line and had a long conversation with a tech.
The owners manual states that when using the flange block you must use a "power beyond type valve"
I have the valve plumbed just like the old one was. The loader works, as does the 3 pt but just seems weak to me.
The tech told me to order the power beyond plug and plumb the power beyond back to the flange and run a return line to the sump under the seat. He said this will get me full power to the loader and three point.
Give me your thoughts ? Does anyone have a L275 /L235 set up with a loader that can confirm this ?
Thanks
Thanks
