Pto ???
melvinhatcher
L3301HST, LA525FEL, 66" QA BUCKET, L8455CRUISE CONTROL KIT, WR LONG 3RD FUNCITIO
Feb 16, 2016
192
Edgewood Maryland
What am I doing wrong? First time hooked up the wood chipper to my L3301, push in the clutch, engage the PTO, slowly release the clutch, increase the rpms, stand up to dismount the tractor, and the tractor shut off. I have park brakes on, and the HST is in neutral. :confused:
fireflame9978
US
You need to flip the seat. You have 2 seat switches for the seat. One is when your staying in it, the other is to flip the seat as for like backhoe attachment. You might check the operators manual for sure.
Sent from my SM-G900V using Tapatalk
seanbarr
B7100DT (sold) - Branson 3520H
Feb 1, 2013
384
Deer Park, WA
Not to sound like Capt Obvious, but shouldn't you consult with the operator's manual?
mdhughes
L3901DT
Dec 10, 2014
1,331
1,016
Ste Geneveive county, MO
melvinhatcher, as fireflame9978 saqid, you need to flip the seat up and have about two second to do that after you get off the seat. Once you do it a couple of time it becomes second nature. First couple of times I use the Woodmaxx chipper it didn't come easy to get up and flip the seat. Now I have no problems doing it. As seanbarr added, on page 45 under "Stationary PTO" in the "Operator's Manual" it talks about this.
2,838
melvinhatcher, as fireflame9978 saqid, you need to flip the seat up and have about two second to do that after you get off the seat. Once you do it a couple of time it becomes second nature. First couple of times I use the Woodmaxx chipper it didn't come easy to get up and flip the seat. Now I have no problems doing it. As seanbarr added, it does that about having to do this in the operator's manual.
How you like that chipper???? Model?
I was real close to getting one.....but I went a different route - ran into a nice stand alone model.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
No sir, I did not check the operator's manual, that is why I post the question here with other kubota owners for help. My older tractor that I have used with this chipper is a 1948 John Deere M, which does not have any safety switches, therefore I did not suspect any conflict from a safety switch. At any rate, I truly thank everyone for the responses that put me on the page in my operator's manual to solve my lack of knowledge with the L3301 vs John Deere M PTO system.:rolleyes:
mdhughes
L3901DT
Dec 10, 2014
1,331
1,016
It works really well on the L3901DT I have. It is a Woodmaxx WM-8M. If you look at this post you can see some of the work I did yesterday with it. The pile of chips is about 4' tall.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
mdhughes, thank you for your patience, and at my age (75) I am not able or agil enough to jump up and flip the seat before the engine shuts off. Therefore, I tried setting the park brakes, HST in neutral, and flipping the seat prior to starting the engine, then engaging the PTO, setting the RPMs and I was set to go. Again thank you so much from the bottom of my heart.:)
Buffalo
L3901, FEL, mower deck
Mar 17, 2016
102
37
Oklahoma
Don't tell anyone, and don't do this, but a cable tie will hold the seat switch closed. I'm a featherweight, and bouncing around on the seat was a bit of a problem. The cable tie is easy to remove if you need to, and that way
you won't have to admit to anyone that you bypassed the "dead man" function.
Having grown up on a horse, I know that getting off quickly can be very important sometimes (actually it is a learned art form). That is at odds with the idea of staying aboard in the event of a rollover of course. To each his own I suppose.
Bear in mind that you probably shouldn't bypass the safety function and you should just use the seat belt to stay aboard anyway.
This note isn't worth $0.02.
6,668
Hey Buffalo, can you post a picture of that safety switch you have on your horse? I want to adapt it to my wife's mower!!:D
My wife needs one. She has a 29HP, 62" Grasshopper mower that travels faster then a mower ought to go. She weighs in at about 110#. I can be out in the shop working and hear the engine miss and fire right back up and then do it again. Not enough weight in the saddle, I guess.
8,790
Simple fix, just put a couple bricks in her pockets. :D
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Good morning Buffalo, there is not a reason for me to bypass a dead man function. All I done to initiate the stationary PTO function on my tractor was, set the parking brakes, place the HST lever in neutral, and flip the seat up prior to starting the engine, disengage the clutch by hand and shift the PTO lever in gear, set rpms and I am set to chip wood. Just a matter of flipping the seat up, prior to starting the engine, solved my problems without bypassing any safety features. :D
Buffalo
Mar 17, 2016
102
37
Oklahoma
Took me a couple days to get around to remembering to take a photo. Sorry ! There are two cable ties in the photo. This is with the seat on my L3901 tilted forward for visibility. The shorter cable tie does the actual job, and the longer one keeps the shorter one in place.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
With a little ingenuity all of these safety things can be bypassed, but remove the wire or other method when done working the chipper.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Bypassing factory installed safety device is a dangerous thing to do. I have found it is easy & safer to work in conjunction with all factory safety devices, once you read your owner's manual. :rolleyes:
