PTO speed
dew
l200 kubota,bushog,rear scraper blade and carryall.
Nov 28, 2013
22
elizabethtown,ky. usa
I have a l200 my PTO speed is 650 but my brush cutter is rated at 540 will it damage my tractor or brush cutter? Thanks for any help.
Sent from my Nexus 9 using Tapatalk
2,914
How do you know that your pto is turning 650? Because that is what is showing on the tach on the dash? Or you have a device measuring the RPM's?
Running at that high of a rate does not sound like a problem until you look at the percent over revving that it is turning - spinning it at 650 is a full 20% more than you should.......
Is there not another lever that changes the PTO rpm's???? Most tractors have a multi select lever that will change the PTO speeds.
if not,
I would run the engine rpm's back a hair, if 650 is rated at the top end - I would drop back a little engine rpm, cutters are designed via BLADE tip speed, by spinning it faster, it cuts better I am sure - but if something is hit, then it will do some serious damage to a turning part of the cutter or you tractor.
9,788
Simple answer most likely not an issue!
If your worried just run the throttle a little less. ;)
8,886
if not,
If I have to hay my yard, I'll put the pto in second gear and run the rpms up to the pto line on the tach. Running the finish mower around 720 rpms :p gets the blade tips spinning a little faster and cuts down on the stuff it misses :D if the grass is normal cutting height, I'll just run at 540 :D
