Premium or Super UDT fluid?
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
Hi all, up here in Canada I went looking for Super UDT2 fluid, as I have read on this forum folks that go state side and import it.
I sent an email to my dealership salesman, and he told me that in Canada, the Super UDT2 fluid is rebranded as Kubota Premium UDT fluid.
Can anyone here confirm this? I am not fully confident on my dealership but it is the closest one I have.
CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
Sep 27, 2015
568
Central FL
Can you compare the specs for the Premium UDT and SUDT2 to see if they match?
http://www.kubota.com/part/lubricants.aspx
Googling - I found this: http://tractorpoint.com/forum/kubot...1/Super-UDT-and-Premium-UDT-Hydralic-oil.html (printed below). However I this seems to apply to "Super UDT (SUDT) and not Super UDT2 (SUDT2) - so it may not be what your looking for.
The only reason we have "Premium UDT" in Canada instead of "Super UDT" is the legal beagles said so.
The name "Super UDT" is a trademark of Kubota USA, and as such must be produced by them, or under license to them, and to their specifications. This only makes sense since they would ultimately be responsible if, for example, it really was inferior and caused damage, for which they would be liable.
"Premium UDT" is however a trademark of, and produced by Petro-Canada under license to, Kubota Canada. Although I have not been able to get a straight answer from either Petro-Canada nor Kubota, several sources 'in the know' have unequivocally stated that it is really Petro-Canada's Duratran Synthetic.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
I have been recently researching that question myself.
Rumour is that Kubota Premium UDT is actually rebadged PetroCan Duratran XL. If that is the case, then it is a synthetic and the basic specs are is comparable to SUDT or SUDT2. Unfortunately, I have yet to find the specs for Premium UDT to confirm the rumour.
This chart summarizes what I have been able to verify from manufacturers data sheets comparing the Kubota fluids against some others available in Canada: Duratran XL, John Deere Hyguard Low Viscosity (which some suggest as an alternative to SUDT2) and Amsoil 5W30 All Weather Tractor/Hydraulic oil (which is what I have in mine right now, and is also touted by some as an SUDT2 alternative).
............................... Kubota ............... Petrocan .... J. Deere ... Amsoil
.......................................................... Duratran ... Hyguard . All Weather
....................... UDT ... SUDT .. SUDT2 ...... XL ......... Low-Vis ..... 5W30
Gravity,
degree API ....... 29.5 .... ND ..... 34.5 ...... 35** ........ 34.5 ......... ND
Viscosity
@ -40°C, cP .... 18300* . ND .... 16000 ... 13500 ...... 17000 ..... 19243
Viscosity
@ 100°C, cSt ..... 9.5 ...... 9 ........ 8.1 ....... 8.3 .......... 7.1 ........... 9.8
Viscosity
@ 40°C, cSt ........ 60 ..... 45 ....... 37 ........ 39.2 ......... 33 ........... 53.7
Viscosity
Index ................. 140 .... ND ...... 199 ....... 195 ......... 195 .......... 170
Pour Point,
°C max ............... -35 .... -46 ...... -42 ....... -50 .......... -51 ........... -50
ND = No Data.
*spec listed as @ -30°C for this fluid. Typo? or because pour point is -35?
**Not published as such, but derived from MSDS.
I was really surprised by the Amsoil numbers. It's a lot closer to UDT than it is to the synthetics. I am now considering DuratranXL instead.
PS: sorry about all the dots. It was the only way I could get the columns to align. Maybe the site admin could enable charts in the editor??? ;)
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,491
511
I waiting to try something my next oil change. I noticed after I did my first oil change on my B2620 and put the Premium UDT in it the hydro whine got louder compared to the factory fill. (on my third oil and filter change now.)
So last time I was in the States I bought a pail of Super UDT just to see if it makes any difference.
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
ItBMine, I would very much like to hear about your results to your test. I should have paid more attention to mine. I bought my used 2014 BX25D when it had only 47 hours on it. It probably had SUDT from factory, because it had not been changed. Only a week or so after I got it, I changed the engine as well as the HST and front axle fluid. Used Premium UDT from Kubota. I have noticed the whine, but I don't have much time behind the wheel before changing the fluid to compare with.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
If he can get the specs, it will be educational.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
From my local PetroCan supplier, Duratran XL:
20L pail -- $101.60 ($5.08/L)
4 x 4L jugs -- $94.50 ($5.90/L)
From Cooy Bros. (large Toronto dealer) website, Premium UDT:
20L pail -- $106.01 ($5.30/L)
1 x 5L jug -- $28.05 (5.61/L)
Both are pretty reasonable compared to the price of cheap conventional types at Canadian Tire:
Certified --$2.95/L. (no specs found, this brand is usually recycled oil)
Motomaster -- $4.35/L (no specs found0
Shell Rotella HD -- $4.73/L (comparable to UDT)
Interestingly, I just came across another potential Canadian alternative: Propoint Semi-Syn TGH from Princess Auto @ $99.99/20L pail ($5/L)
Gravity,
degree API ....... 28.9
Viscosity
@ -40°C, cP .... 15900
Viscosity
@ 100°C, cSt ..... 7.3
Viscosity
@ 40°C, cSt ........ 33.6
Viscosity
Index ................. 191
Pour Point,
°C max ............... -48
(now I'm really questioning the benefit of Amsoil, given it's closer to $16/L!)
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,491
511
I hope they reply to you Southernfarm. So many speculations of who makes what oil.
I've done a couple oil and filter changes and mine got louder compared to the factory fill that was in it for the first 50 hours.
Torch....Cooy is just a bit cheaper for the Kubota UDT then up here by the Sault. and even when our money was close to par......the pail of SUDT I bought from Skinners in Michigan was about the same price. Normally everything is cheaper in the states.....but the oil wasn't.
steveInMaryland
L35, b2710
Nov 23, 2015
98
marriotsville, MD, USA
I have this from an un-authorized Kubota mechanic in Canada whom is also a friend. For whatever reason Kubota Canada labels Super UDT2 as Premium UDT2. Can't remember the actual label but maybe only UDT vs UDT2.
Have your mechanic look at the container and verify it is 100% synthetic. If it is then it is Super UDT2 available here in the states. If it is semi-synthetic then it is UDT2 as our equivalent.
Based on your temperature variations compared to ours I am guessing the only thing they sell there is Super UDT2 (Premium UDT2.)
Hope this helps.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
It doesn't mention "synthetic" or "semi-synthetic" at all.
Front label:
"Premium UDT Hydraulic/Transmission Fluid".
"Built to last".
"For tractor transmission and hydraulic systems. Compatible with wet disk brakes".
Repeated in French.
Part number 72000-03406.
Rear label:
"Kubota Premium UDT Hydraulic/Transmission fluid is a premium quality, Kubota approved tractor transmission and hydraulic/wet brake fluid incorporating the latest additive technology. Premium UDT provides high resistance to high temperature breakdown, excellent seal compatibility and anti-wear protection. Premium UDT meets the requirements of John Deere J20D. Performance is similar to Premium UDT with the addition of superior low temperature properties. Premium UDT is a winter grade Universal Type Tractor Fluid. For a complete listing of tractors which can use Premium UDT, consult your Kubota dealer."
"Trade-mark of Kubota Corporation. Used under license."
"Kubota Canada Ltd. 5900 14th Ave. Markham, Ontario L3S 4K4."
"Made in Canada."
Also repeated in French.
I find it interesting that the performance of Premium UDT is similar to the performance of Premium UDT. I wonder if they meant to say it is similar to the performance of regular UDT. IE: Premium UDT = winter grade, Regular UDT = summer grade?
The "Made in Canada" line suggests this is not the same fluid as the US-only UDT2.
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
Well my sales guy only sent me the MSDS sheet. No use at all. I read somewhere that the USA fluid is made for Kubota USA, and there is a licensing issue to sell same in Canada. My guess would be that Kubota Canada had to go to Petro-Can with the formula to make it for them. Or they just rebranded.
When I purchased my BX it had 43 hours on it, so I went to the above dealer/sales and purchased a 20L (5gal) pail of Premium UDT2, HST filter, 5L Jug of Kubota Engine oil and engine oil filter. The total bill with my 13% taxes came out to about $130 if memory serves correctly.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
An MSDS might provide some very basic physical info, such as density or kinematic viscosity. Can you post a copy?
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
MSDS's are available online. Search msds plus name of product.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
Yes, I tried that. Not getting any hits on the Canadian "Premium UDT" product, just the US UDT/SUDT.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
PDF is an allowed format for an attachment on this board. When replying, click the paperclip icon to browse for and attach the file.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
Ok, so at a glance: it's made by Shell, not Petro-Can. Gravity degree works out to 29.3, And it's mineral oil based.
This is not comparable to SUDT2. It's regular old UDT.
EDIT: On second look, it's thinner than UDT. Viscosity @100°C is 7.1 (same as JD Hyguard Low Viscosity), pour point is -57°C, which is the lowest of any I've looked at. Definitely looks like a winter grade formulation.
torch
Jun 10, 2016
2,757
976
Muskoka, Ont.
Well I've dug through a stack of MSDS and TDS on Shell Canada's website and can't find a match from their standard product lines. Either it's custom formulated for Kubota, or someone is fudging the numbers. The closest I can find in terms of viscosity and pour point are actually ATF fluids.
