Posthole digger ?
tater pop
64
Maud texas usa
Happy thanks giving to all. I saw a thread on three point hole diggers not getting high enough off the ground on the three point. I have tried to search and can't find it. On the top link of the three point what hole will cause the tip of the aulger to be the highest off the ground?
5,128
Lowest of all the holes will give you the greatest lift. ;)
djm1204
L4600 HST, FEL, Root Rake, Land Pride Grapple, Two way radio
Aug 11, 2014
84
Dunnellon, FL, USA
I am in the market for a post hole digger - may I ask what brand you are using ? Happy with it ?
Any comments - things or brands to look for - avoid ?
Thanks
MattyNH
Kubota L3800DT, R4 tires, Bradco Forks, Third function valve
Oct 15, 2014
41
Lake Winnipesaukee New Hampshire
I borrowed a post hole digger from a friend earlier this summer.. The post hole digger is from Tractor Supply..Worked very well for me..Has a 12 inch bit on it..Id like to buy one..But the problem is for me..Its a attachment I will use very little..But at the same time..When needing to dig a hole..Its sure nice to have..
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
I've used the snot out of a Danuser on the Oliver 1265. Works great.
Old trick, when storing, dig a hole where you want to store it and keep putting the auger back in the same hole, it holds it perfectly for the next hook up!
5,128
That works fine if you live in a dry area, and we all know how dry California is these days. :eek:
Ways I could store equipment in AZ I could never do here, it would just rust right into the ground if I tried to store my PD in a hole! ;)
4,544
You couldn't store a post hole digger in the ground here either. Would end up with the digger stuck in the ground. Summer it's like concrete. In the winter it would sink to the top of the auger. Had to put pavers down for the jack on my trailer. Jack sunk almost a foot in two weeks :eek: had to hook the chains to the draw bar on the 3ph to get it out.
4,544
Where do you guys live, in swamps? :D
As with all advice, your mileage may vary... lol!
Old cotton field :eek::rolleyes: worst soil I've ever seen. Clay/loam very little solids. Summer it's concrete. Winter it's mush
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
27
Ventura Ca
I built a h frame 6x6 up rights and 2 2x6 cross members and hang my auger while not in use makes for a very easy hook up by yourself no weight to pick up just back in pin and your ready to work.
bcbull378
Sep 6, 2011
579
27
Ventura Ca
Thanks
I have a Danuser auger works great
