oil change
2,831
turn over?
or start?
2,056
Which oil was changed (engine or something else)?
6,626
If you didn't change anything else you could probably put that old oil back in and it would run fine!!! :) :):)
NorthwoodsLife
Oct 15, 2021
1,243
1,231
Wisconsin
Most Kubotas have an oil monitoring facility built in. It takes the newly installed oil and tests it in a miniature processing plant inside the oil pan.
If you put in substandard oil, the whole machine shuts down until engineers from Japan come and reset it.
  • Sad
Tioga Tim
B2620
Nov 11, 2020
42
Upstate New York
X2 on the levers. Check your PTO lever. I often catch mine with the hammer loop on my coveralls when getting off the tractor, and if the tractor is not running when it happens, I don't realize it.
Tim
