Oil Change
Gecko76
Kubota B2150 (1996) Front Loader
Jan 2, 2022
Setauket, NY
Hello from NY......I am on a "slippery slop"........ am doing an oil change at 650 hours on my B2150 4cyl Diesel and am confused. I have been using 10w30 regular.
1. Should I be using Regular OIL or SYNTHETIC OIL, seem recommended
2. Regular motor OIL or OIL designated for DIESEL Engines, confused as to benefit if any on small diesel
Thanks
lmichael
Kubota G2160
Apr 23, 2021
845
439
Rockford IL area
Lots of oil threads here. Do a search and form your own conclusion. A lot of folks though like the Rotella T6 5W-40. But, hey, it's your machine
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Hopefully not your first oil change for this machine, Use diesel rated oil and change often what is best for your tractor.
nbryan
Jan 3, 2019
1,423
943
Hadashville, Manitoba, Canada
Thanks
Apparently the Kubota 10W-30 diesel engine oil is a "semi-synthetic" whatever that means. So is the 10w-30 diesel oil I get from Canadian Tire. Minimum CJ-4 is the rating to look for.
NowI'm using 5W-40 Rotella T6 and I like it's performance, really cold starts and hot summer workouts both.
jyoutz
Jan 14, 2019
3,624
2,718
Edgewood, New Mexico
Whatever you use, it must be diesel engine rated, not general motor oil.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,163
1,157
E.
Thanks
good question which alot of new owners ask:
use diesel rated oil
synthetic, semi, or conventional are all OK. I would use synthetic for many reasons. When your tractor was made I would guess it came with diesel rated conventional oil.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
Diesel oil. Definitely.
I always lean to synthetic. When it comes to full synthetic or semi, my question is always "are you going to change it because you hit the hours or miles?" Because if you'll be changing it annually even though you didn't put the hours/ miles on a machine, full syn isn't really going to do much over a semi.
Turfturd
B7510
May 20, 2021
53
Missouri
Thanks
I use full synthetic. I usually don’t hit the hours used mark. It’s more of an annual thing. Synthetic oil does not absorb moisture as much as “organic” oil or regular oil.
Just my 2 cents.
3,058
Let me break in down for you in layman terms -
Diesels are really bad at getting little particles past the rings and those particles get into the oil unlike gassers. SO what to do - diesel oils have the ability to contain this particles in such a way that they do not harm the bearings and whatnot. NON diesel oils DO NOT have this ability. SO ALWAYS use diesel oils on diesel engines.
And as for synthetics............ they are not any slicker than conventional oils, and they don't really cost a lot more these days either. WHAT they DO is this - they flow better in cold, much better in cold, the wear on a a engine is created when you turn your key - after it is running and warmed up.... very little wear occurs.
Another synthetic advantage - it does NOT break down as fast, the base of oils is higher and more refined making it a "better" overall oil. AS the old argument has been discussed here 6,341.37 times ......... why use synthetic if I change my oil every year or 50 hours???? WELL ...... it is like this, IF synthetic "last" longer, and works better in cold start up.... why NOT use it? Way too many tests have been run to prove that it will do the little things better than conventional oils.
But... your pocketbook and your machine - treat it how you see fit!
