Any disadvantages to using off road diesel in my new Kubota tractor. The station that sells turns over their tanks frequently. The Kubota tractor dealership is across the street from the station that sells it.
I use off road diesel in all five of my Kubota tractors.Any disadvantages to using off road diesel in my new Kubota tractor. The station that sells turns over their tanks frequently. The Kubota tractor dealership is across the street from the station that sells it.
This is on a licensed road truck with farm tags.Even know of a few farm vehicles that run it with no issues(don't get caught as the fine is $10000 and you have to pay taxes on all off-road diesel purchased within the last five years).
The gelling issue is not a factor of the fuel being off road. Off road and the taxed fuel is the same, with the same additives.Nope, run Off-road if you can way cheaper than On-road. No difference, my Snowmobile Club runs Off-road in both our Case 195 Puma Tractor/ Groomers both are Tier 3 emission's machines and cost over $195K each. Zero issue other than gelling over night if not plugged in.
Sorry the DEF Fluid would freeze up on them. Shouldn't be an issue anymore, we finally built a Heated barn to store themThe gelling issue is not a factor of the fuel being off road. Off road and the taxed fuel is the same, with the same additives.
DEF fluid does freeze(12 degrees F),that is why the DEF system has a electrical heaters(in GM 3 heaters((tank, lines, and injector)and delays system from operating until the heaters have time to work. This is why all DEF system parts are made of plastic to allow for expansion.Sorry the DEF Fluid would freeze up on them. Shouldn't be an issue anymore, we finally built a Heated barn to store them
Also in reply found this on a few VW's and volvo's that are not farm vehicles just cheap owners, also have worked on a few waste vegetable oil burners(smells like french fries when running).This is on a licensed road truck with farm tags.
I run it all the time and is perfectly legal in a tractor.
My son had a beater Beetle diesel that he ran on red fuel, used hyd oil, used trans fluid, and veg oil... never missed a beat until the trans failed.Also in reply found this on a few VW's
Just curious as to why you running anti gel down here? I honestly didn’t even know they sold it down hereMy off road station is actually my closest Diesel source. Since I regularly store ~30 gallons in 5 gallon cans at the farm, each can gets a squirt (1 teaspoon) of anti-gel.
Sorry, yes I got my additive mixed up. I absolutely intended to say: Biocide No Diesel anti-gel here.did you mean algecide or some other additive?
Now yes I use red dyed off road diesel in both tractors as well as the sawmill. Because I do store ~30 gallons of fuel in 5 gallon cans at the farm that may or may not get used for a year, they get a squirt (1 teaspoon) of Biocide. I try to rotate my cans, but sometime stuff happens.
