New old tools
torch
Jun 10, 2016
2,912
1,173
Muskoka, Ont.
I don't know why a drawbar thread would need to be 1/2", especially with a Morse Taper. They are inherently self-locking. More so than steeper tapers like R8 which typically utlize 3/8" or 10mm drawbars. I would think it would take a pretty impressive vibration to shake an MT shank loose -- maybe swinging a boring head or fly-cutter on an interrupted cut?
But then, I've never tried an MT shank for milling operations. Just lathe centres (which are under pressure). So I could be wrong.
Oh and Whitworth??? Whitworth??? Is that thing a custom part for an old pre-war Myford lathe or something?
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
936
1,779
Baranduda, Victoria, Australia
No idea on the need for a drawbar with a morse taper for milling - haven't done enough to know. But now that it's there I guess I'll use it.
Whitworth was common here pre-metric. Maybe it's still used in new collet chucks as there are a lot of machines around that need it ? It seems odd in this case to have a 1/2" Whitworth drawbar thread in the end of the MT3 chuck when the 1/2" drawbar won't fit through the MT3 spindle.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
466
371
NH
Wentworth is/was common in fire hose connections. It has a 55-degree thread as opposed to NST 60-degree thread. Can be a problem when attempting to connect couplings of the two types.
Paul Allwood
Jul 8, 2025
936
1,779
Not much time in the shed today, just long enough to make a bracket to refit a guard over the back gears closest to the chuck on the old lathe.
PXL_20261107_071025073.MP~2.jpg PXL_20261107_071011903.MP~2.jpg PXL_20261107_071400235.MP~2.jpg PXL_20261107_072117980.MP~2.jpg PXL_20261107_072834394.MP~2.jpg PXL_20261107_072844405.MP~2.jpg
Good as new....or maybe good as old.
Paul Allwood
Jul 8, 2025
936
1,779
I went fishing through bits supplied with the lathe today - it turns out I have a complete set of all change gears listed on the brass imperial and metric thread pitch data plates. Pretty amazing for something this old.
Changing change gears is a new thing for me so I tried setting up to see if I could make it cut a 5 mm pitch. Not trying to cut a thread, and might never need a 5 mm thread pitch, just testing to see if I can get the pitch right. If I can get one right then i must have interpreted the brass plate correctly. I picked 5 mm to make it easily measurable. Pretty happy that it worked.
....well it actually worked on the 2nd try.
The brass plate for metric threads listed gears 50-40-80-127 for a 5 mm pitch. Marion, my amazing wife, was watching the first try that didn't work - the pitch was a little under 4.5 mm. Marion looked at the list of gears I was supposed to have used. She also noticed a gear on the bench with '40' stamped on it and asked if the 40 was the number of teeth. Haha - I was supposed to have used the 40. Turns out I fitted a 45 instead. Once I replaced the 45 with a 40 all was good and we had a 5 mm pitch.
I know it's just gear ratios , but I still think it's pretty amazing that I can cut a metric thread pitch on a 500 year old lathe.
I don't know if it's for everyone, but I find it really satisfying getting something old like this working....a bit like our old B7200.
5,703
Thats pretty cool man!
I have a similar set-up on my Craftsman lathe, although I don't have your patience.
I have played with the gears a few times, but only for changing speeds and feeds. Never threaded anything on it (yet).
I (obviuosly) have never seen your lathe, but one "trick" that helped me was to "cut a strip" of regular printer paper, and run it by hand into the gears, when changing them out while they are still only "semi-tight".......Then tighten them fully.
On my little Craftsman, it acts as a "shim" and properly spaces the gears.
It made a HUGE difference in how it sounded and ran.
Good luck sir!!!!!
(y) (y) (y) (y) (y) (y)
Paul Allwood
Jul 8, 2025
936
1,779
Good luck sir!!!!!
Next time you're driving past....
Thanks for the tip on the paper to set gear clearance - I'll fit it a try.
torch
Jun 10, 2016
2,912
1,173
Muskoka, Ont.
You might want to get your prescription checked -- you seem to be having trouble reading numbers today! ;)
Nice to see you have a proper 127 tooth gear in the set -- that's the magic gear that turns out true metric thread pitches on a lathe with an imperial fead screw. Some older/cheaper lathes approximate the ratio using smaller gears.
Now I realize that you were just scratching the surface to check the pitch, so it doesn't really matter in this specific case, but when cutting metric threads you can't go by the threading dial. I noticed that you backed off the tool then ran the carriage right with the spindle turning as if you were cutting an imperial thread and setting up your next pass to engage the feed screw when the threading dial numbers aligned.
The problem is the threading dial gear relies on being an exact ratio with the driven gear -- and nothing goes into 127 evenly. So you can't disengage the feed screw or you will destroy your thread on the next pass. You have to cut metric threads as if you don't have a thread dial.
Cut your relief groove first and stop the motor / withdraw the tool at that point each pass. Don't touch the feed screw lever until the thread is completed and checked! Reverse the motor and allow the feed screw to move the carriage right past the start of the thread. Shut the motor off, set your next depth, and cut the next pass in forward. Rinse and repeat.
Personally, I switch between needing to cut a metric vs an imperial thread all the time but I'm old and easily distracted. To prevent disaster I use the above technique now regardless of pitch so I have the same muscle memory and don't accidentally release the feed screw when cutting metric threads.
torch
Jun 10, 2016
2,912
1,173
Muskoka, Ont.
If you want a detailed explanation of the threading dial and how it works, I just stumbled over this:
Paul Allwood
Jul 8, 2025
936
1,779
Thanks for that explanation - that's excellent. This lathe doesn't have a threading dial. I'm waiting on my electrician mate to help me with switches and wiring so I can run the motor forward and reverse, then I'll be able to test cut a thread.
Paul Allwood
Jul 8, 2025
936
1,779
I don't have a threading dial on this lathe, but didn't know how they worked either. That's great - thank you.
3,196
I recall that you said that someone told you the motor was not “suitable“ for VFD operation. I don’t think that statement is really 100% accurate and suggest that you discuss it with the electrician. It could be that VFDs could help the installation if it is a multiphase motor that you don’t have the supply voltage and phases to supply.
It may be a multiple phase motor or have many leads out for various voltage connections and that may make it more expensive or difficult to use a VFD to supply power. And you may have absolutely no need for the VFD so ignore this if that is the case.
From my understanding the use of VFD can shorten the life of the stator insulation but could be used regardless of that fact.
Paul Allwood
Jul 8, 2025
936
1,779
Be careful what you believe....
I put some info on a Metalworking forum about the big old lathe we've just bought, this included some dimensions.
This morning I was Google searching to see if I could find any manuals or any more info on its history and I got the attached AI results.
The numbers are what I measured on our lathe and posted on the forum....the AI search engine found and quoted the info I posted and fed it back to me as an answer, complete with links to my forum post.
I didn't do this on purpose, but it seems it would be pretty easy to create your own facts.
ken erickson
Nov 21, 2010
1,461
2,761
Waupaca Wisconsin
I have experimented with AI for the last year and have come to the conclusion that most initial answers , when asked for technical specs or details, have an error rate of about 98% ! For the most part all AI does is harvest information from forums and regurgitates posts regardless if they are based on facts or not.
WanderOn
Kubota B8200D, B300A FEL
May 27, 2024
245
606
New England NSW Australia
I bought a bigger lathe off Facebook Marketplace this morning - much bigger than my current lathe. The bed is about 5' long. It's old and will need some TLC, but it's solid.
It also comes with a bunch of useful bits - big 4-jaw chuck, big faceplate, fixed and travelling steadies, a good selection of gears plus a few old turning tools.
The 3-jaw chuck is weird - I've never seen one quite like it. Has anyone seen one of these chucks and know anything about it ?
While we were there I also accidentally bought a mill drill that he was also selling. It's not a Bridgeport, but it will be a big step up from milling on my little lathe.
I got both for $1,600. Pick them up next weekend.
Now rearranging the shed is another project.
I think I'll sell my existing small lathe and 2 drill presses, probably for as much as I paid today.
Bit slow on seeing thus thread. That's an awesome set up.
Got to admit a bit of shed envy.
Paul Allwood
Jul 8, 2025
936
1,779
I've been doing a little reading on getting a lathe setup properly rather than just continuing to play, but there's almost too much information. Like a restaurant with a big menu - it's all good but how do you choose ?
From what I've read it seems levelling is about the first thing I need to try to get right, but I don't currently have a machinists level - do I need one ? Then check it by turning and comparing diameters on a test bar 10-12" apart.
But after that....I'm after advice re what to tackle and in what order:
- Chuck runout
- Headstock alignment
- Tailstock alignment
- What else ?
I'm not expecting to get it perfect, but keen to get it as good as I can.
Thanks in advance for your ongoing help.
Workerbee
Zd21
Mar 1, 2020
401
288
MN
Any decent level that checks out to be accurate can work. Even a length of clear hose with colored water could.
lynnmor
B2601-1
May 3, 2021
1,836
1,636
Red Lion
Getting all of the feet supporting the machine equally is important so that there is no twist in the bed. Using a precision level you can see that twist and compensate. It is true that level may not be important but it allows you to see which corner may need more or less load.
My lathe has six feet and I can adjust level on the four corners and then bring up the middle to suit.
torch
Jun 10, 2016
2,912
1,173
Muskoka, Ont.
Technically, no. A lathe doesn't need to be level: many a ship or submarine has a lathe for making repair parts and those are only level at random moments. But a lathe needs to be straight and true and the easiest way to ensure that (on dry land) is to use a level.
A machinist's level is nothing magical, just more sensitive with a precision ground base. It still uses a bubble in a tube but the tube is longer with a gentler, more precise, curve to make it more sensitive. I have an 18" Starett 98Z (inherited decades ago but Starett still offers the same model at $1000 a pop). The advertised accuracy is only 5 thou per foot, so it's a starting point to get things close; do the best you can with what you have for now and keep an eye open at garage sales or auction sites for a reasonably priced machinist level. You won't need it very often (mine gets more use leveling billiard tables than machines). The other steps you mention are still required to fine-tune the accuracy, starting with stoning any dings, then adjusting the gibs then aligning the tailstock.
One thing to remember: a used lathe will be worn. Most wear will occur on the bed near the chuck. Your ability to fine-tune the lathe will depend upon how worn things are. The later steps of fine tuning with a piece of bar stock will undoubtedly be a matter of finding the happy medium.
ken erickson
Nov 21, 2010
1,461
2,761
Waupaca Wisconsin
I purchased a very nice LaBlond Regal lathe that was owned by Browning's warranty repair facility in Arnold Mo back around 1990. Fantastic old school machine shop quality lathe but Browning used it for modifying 2 9/16 16 gauge A5 forends to 2 3/4 inch when doing the A5 16 gauge modifications. They would bore the inside hole in the forend longer by hand holding the forend, and using a piloted cutter in the chuck, then just push the tail stock by hand with the forend supported with a mandrel. Problem was that the wood filler Browning used had silica as a ingredient.
Long story short the bed of the lathe was saddle backed by the back and forth of the tailstock in a very isolated area and had been pretty much reduced to scrap. I did know that going in and was able to use the lathe for certain shotgun barrel internal choke tube installations.
