New old tools
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
936
1,779
Baranduda, Victoria, Australia
In about three hours today I turned one simple piece on the small lathe and drilled four holes. Sometimes all of the time is in the setup.
The piece I turned was to match the spindle diameter to locate the bull gear and cone pulley. The rest of the bits are to stop it falling right through to make sure it stays partly in the bull gear and partly in the cone pulley.
Next it was over to the drill press as my recently acquired mill drill doesn't have enough Z-axis travel. I used the locking pin hole in the bull gear as the guide for the drill.
Drilling the holes didn't take long. The time was in the chin scratching and setting up.
I finished with four new holes that line up nicely.
I'll fill and smooth over the the original worn holes with JB Weld liquid steel epoxy.
I checked the alignment of each of the new holes by rotating the bull gear slowly and letting the pin drop in under its own weight.
Next job is to make a new locking pin.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
466
371
NH
And Paul, I wish I had your skills and tools.
I also wish we weren't 16,000km away...
Paul Allwood
Jul 8, 2025
936
1,779
The difference in the depth of the slots in the hex piece that screws into the bull gear on the big lathe dictates how far the locking pin can slide into the cone pulley, originally only 10 mm. When I drilled the new locking pin holes into the cone pulley I drilled them 18 mm deep to allow for increased engagement of the locking pin.
This required either modification of the hex piece, or a new one. I decided to have a go at making a new one.
So I needed to cut a thread - 3/4" x 16 TPI. This is only the 3rd thread I've cut since tech school in the mid 70's. The things I remembered (don't know why) was to set the compound slide to 59 degrees, and leave the half nuts engaged since I don't have a thread chasing dial. I ground a high speed steel tool and got started. Pretty happy that it actually worked and screws in where it is supposed to.
Paul Allwood
Jul 8, 2025
936
1,779
Next step was over to the mill drill to mill the slots. All was going well, albeit slowly, right up until the smoke got out of the motor windings or motor start capacitor. I'll let it cool down and sort it out tomorrow.
Yooper
3901 LA525
May 31, 2015
1,766
945
NE Wisconsin
I’ve seen that magic smoke myself. It didn’t end well. Hopefully you catch the break that I didn’t!
Paul Allwood
Jul 8, 2025
936
1,779
The capacitor has definitely failed - it's expanded lengthways and has liquid capacitor guts leaking out. I haven't measured winding resistance - without knowing the specified winding resistance for the start and run winding I won't know if there's a short partway through. Might replace the capacitor and see if it runs.
Paul Allwood
Jul 8, 2025
936
1,779
I don't have a suitable capacitor here to try the original mill motor so I stole a motor off a power feed I made for the router table when I built our kitchen years ago.
With some mods to the mounting bracket, a sleeve to fit the pulley to the different size motor shaft, and some wiring modifications I had the mill up and running again and managed to finish milling the slots I started yesterday.
Locking pin engaged - bull gear and cone pulley locked together for normal high speed operation.
Locking pin disengaged for low speed operation using back gears.
So why did I do this ? I often get to the end of something and ask myself that, sometimes I can't remember, sometimes I can remember but I question the value.
The piece that I made with the slots replaces the hex piece in the pic below....
With the original hex piece the maximum bull gear to cone pulley pin engagement was about 8 mm. With the new piece I made it's now about 18 mm. Hopefully this will result in reduced wear/deformation on the leading edge of the holes in the cone pulley over the next 80 years than over the previous 80 years. That was part of the reason - the other was I wanted to see if I could make a part that required thread cutting and milling some slots.
