New old tools
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
936
1,779
Baranduda, Victoria, Australia
I'm gonna have to paint it orange.
Am I the only one here to have a Kubota mill ?
Paul Allwood
Jul 8, 2025
936
1,779
The mill drill came with a clamping kit. Only problem - the tee nuts are too small and pull through the tee slots in the mill bed. So I made some.
The 2 on the right are too small. The 2 on the left are the right size - I made 4.
The large diameter steering wheel is actually not too bad for feeding in slowly.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
466
371
NH
You going to power steering on this too?
Paul Allwood
Jul 8, 2025
936
1,779
Back looking over the lathe yesterday, I noticed some vibration and runout in the large pulley on the lathe yesterday. Turns out there were a couple of cracks in 2 of the webs.
I made a tool to pull the pulley off the shaft, them cut the centre of of the pulley. One of the webs pretty much fell apart in my hands.
Looks like this crack had been there for a while.
Haven't decided yet if I'll repair the old pulley by making a new centre or if I'll just buy one. Depends on the price of a new one.
Paul Allwood
Jul 8, 2025
936
1,779
So I can keep the lathe running while I sort out the broken pulley (I'll need to use it to make bits to fix the pulley of I go down that path) I bored a hole in an old 9" pulley to fit the shaft and spoke the belt of the compressor which happened to be a good fit. The 9" pulley increases all sides by 33%, so not something I want to leave on there just yet.
It's a nice change to be able to easily grip something this size after having a small lathe for 30 years.
Paul Allwood
Jul 8, 2025
936
1,779
Next job, remove the 3-jaw chuck that has been on for at least 2 years as the previous owner had never changed it. This was so I could measure the spindle runout.
With a big Allen key gripped in the chuck it unscrewed surprisingly easily.
After a clean, first I measured the runout on the diameter of the spindle and got +/- 0.01 mm (+/- 0.4 thou).
Next I checked on the flat face that the chucks and faceplate screw up against. This was even better at +/- 0.005 mm (+/- 0.2 thou).
I also checked for sideways play in the spindle with a brass bar inside the front of the spindle and couldn't get any movement on the indicator.
I'm no expert (first time I've done these checks on a lathe) but I reckon for an 80-90 year old lathe this is pretty good.
Yooper
3901 LA525
May 31, 2015
1,766
945
NE Wisconsin
I’m not surprised about the runout. Seems every old lathe I’ve checked is that way!
I’m putting in my vote for replacing the center of the pulley. It would be a challenging project but a fun one with the new old lathe!
Paul Allwood
Jul 8, 2025
936
1,779
The 2-piece back gear locking pin I made worked ok for a couple of weeks but then came the lathe but on the end started to unscrew and make intermittent contact with the inside of the pulley. I wanted it to be tight but also wanted to be able to disassemble it.
So I have up on the 2-piece idea and decided to make a 1-piece version so I can put it in over and never have to touch it.
To do this I need to disassemble the headstock. Now is the best time for this, before I try levelling and getting it all "setup" properly. This also lets me see what type of bearings are in the headstock and what condition they are in - I didn't know if they were plain bearings or tapered rollers....I was hoping for tapered rollers.
I was pretty happy to find nice big Timken opposed tapered rollers at the front end of the headstock shaft.
It looks like the bearings have got pretty hot. When I get them out and cleaned I'll have a proper look.
The back end of the headstock looks like a nice heavy parallel roller.
There are two o-ring grooves at each end that I've got apart so far but no o-rings. Might have contributed to a lack of oil and running hot.
There must also be some sort of bearing where the headstock shaft splits somewhere inside the cone pulleys ??
I'm glad I decided to do this - at least I know what I'm starting with.
Having decent bearings also makes me think swapping the flat belt and flat pulleys for a series of v- pulleys and vee belts will be ok. If I do this I'll be aiming for more speed steps and quieter operation.
I'm now trying to remove the back gears shaft, but I can't work out how it comes out. I've removed the screws (the only 2) and the handle from the back gear engagement shaft, but I can't work out how to get the shaft or bushes out at either end. The shaft where the handle attaches looks like it's had a hard life, so not too concerned if it gets damaged or even destroyed getting it out as I might make a new one. Tapping the shaft with a brass punch from either end it moves a few mm but feels like it's hitting a hard stop, but I can't see what's stopping it.
All suggestions gratefully received.
Yooper
3901 LA525
May 31, 2015
1,766
945
NE Wisconsin
From what I’m seeing, that shaft has to be one piece. Are the bushings drilled so the set screws lock directly on the shaft?
Paul Allwood
Jul 8, 2025
936
1,779
I think you're right - the shaft does appear to be one piece. The set screws seem to lock onto the surface of the bushings.
Paul Allwood
Jul 8, 2025
936
1,779
The back gears are now removed from the lathe.
The steel bushes were pretty well stuck in so I drilled and tapped 2 holes in each and made a small puller to pull them out of the cast iron housing and off the shaft. I don't think I would ever have got them to move without it.
@Yooper you were right about the shaft being 1 piece. Once I had the steel bushes out I could see what I was doing - just had to rotate the eccentric shaft so that the larger diameter fit through the holes in the casting, then hammer a lot on the end of a long brass punch.
Next trick - work out how the v various bits are held onto the headstock shaft so I can get it out. Hopefully a job for tomorrow afternoon.
Paul Allwood
Jul 8, 2025
936
1,779
So, I managed to get the lathe spindle out today. First time I've removed a large spindle and pretty happy I got it out.
Not being too keen on using a hammer, I made a puller using a length of all-thread and some bits from the scrap rack. Also made a plug to go in the back end of the spindle.
This puller let me ease the spindle out - this was pretty handy when it came to the bull gear starting and continuing to pull off the bush that it's a press fit onto. Not knowing what I was doing and being unable to see what was happening, I don't think I'd have been game enough to hammer hard enough to get it to move off the press fit. Once the press fit bull gear was clear the spindle came out easily by hand.
Now I've got some cleaning to do, and make a new pin to lock and unlock the bull gear from the cone pulley.
One bit that stumped me for a bit at the start was a locking screw at the bottom of this hole. There was another screw above it, and I originally couldn't see the locking screw in the greasy oily sludge further down the hole.
Only one oops (so far). I dropped the cone pulley on the concrete carrying it over to my bench. This cracked a small section out of the flange at the end of the high speed pulley. It won't affect operation, and I think I'll be able to repair it by milling a section out then make a piece to bolt back in.
Yooper
3901 LA525
May 31, 2015
1,766
945
NE Wisconsin
Are you going to replace the bearings? Curious what the price will be. I assume they are class 7.
Paul Allwood
Jul 8, 2025
936
1,779
I was at the bearing supplier yesterday - standard precision bearings are $70 for Timken and $40 for NTN. I didn't get a quote, but he said the price would be about 5 times that for "high precision" bearings - he didn't mention a class and I didn't know to ask. Given that the lathe is about 80ish years old and I only paid $800 for it, fitting high precision bearings seems like overkill.
I think the bearings that are currently on the spindle look pretty good. I can't see any pitting. I'll try to get some decent pics once I've cleaned it all.
What would I be looking for that would tell me that the bearings should be replaced ?
Yooper
3901 LA525
May 31, 2015
1,766
945
NE Wisconsin
You pretty much got it. Pitting. Discoloration from heat would be a concern also as that would signify the temper has been changed which would lead to pitting.
Paul Allwood
Jul 8, 2025
936
1,779
Yesterday I got all of the lathe spindle parts cleaned.
A positive to come from scraping and dissolving decades of greasy grime off these parts is that I found 3 screws on the end of the cone pulley. This is what I dropped and broke yesterday. Turns out the 3 screws held on the separate disc that I broke.
I had also assumed the grooves in the bearing retainers were for o-ring seals. While cleaning I found a couple of small pieces of what must have been felt seals.
5,703
The bearings pictured look good to me. (y) (y)
And that piece you dropped should be "pretty easy fix" for a guy with your talents🍻🍻
Looking good so far sir.🍻🍻🍻
Paul Allwood
Jul 8, 2025
936
1,779
Today I made a new disc for the cone pulley to replace the piece I broke. I started with 8 mm got rolled mild steel, cut the blank with the plasma cutter, turned the OD then bored the ID.
I had been wanting to try some new discs for the grinder, claimed to be good for removal of mill scale. It worked beautifully.
Making this disc on the small lathe reminded why I bought a bigger one.
Also made a little progress in cleaning up the back gear shaft bushes. They were pretty difficult to get out, partly due to deformation from the set screws that hold them in place on the OD, partly due to deformation on the ends possibly from previous attempts at dismantling.
I milled a small flat for the set screws to bear on. Hopefully this will prevent any deformation affecting their removal in future.
One of the bushes, the one closest to the chuck, is cut all the way through along one side and cut through about 80% on the other side. My guess is that this allows the back gear shaft to be locked with the set screw to stop the back gears from disengaging under load.
