Neutral Switch
coachgeo
Nov 16, 2012
2,459
37
Southern OH
General
1. Fuses
2. disconnect removable wires from switch- clean contacts, reconnect
8,315
I'm just going to assume that by green display your taking about is a dash
neutral indicating light?:confused:
If it's not just a Neutral indicator:
If the whole dash is black then you have bigger issues, like dead battery, dirty/bad battery connections, blown fuse.
If it is just a neutral indicator:
Double check that all levers are in the neutral/off position, PTO levers is #1 oops I bumped it in the on position.
bobbyelucas
L3830DT
Sep 1, 2014
Bartlesville, Ok
It is just neutral indicator. I removed covers to top of transmission and cleaned and lubed but it didn't help. Guess I'll try ignition swithch next.
