Mystery bolt
11,311
It's all metric on Kubota, start using the other side of the ruler.
Not really true, there are SAE bolts, wheels are a prime example.
Implements, like a snow blower, and loaders are not metric.
NorthwoodsLife
Oct 15, 2021
1,410
1,475
Wisconsin
As teenagers, my best friend and a fellow shade tree mechanic once told me. Jokingly: "If you finish a major rebuild and find an extra bolt, just put it in the oil filler hole on the valve cover. It'll find its way into the right place"! LOL
He was infamous for stripping bolts or breaking the heads off of them. I told him to figure out what 'snug' means, depending on the part. We used torque wrenches too, but only for things like clutch pressure plates, axle pinion nuts and head bolts. Most everything else was either: barely snug, snug, real snug, or F'n tight. Depending on the parts construction of aluminum or steel, and if the bolts held the engine or axles on.
LOL
I've found many 'free' nuts and bolts after working on stuff. Usually found out where it was supposed to go because something was rattling.
I have always made it a habit to keep the bolts and nuts with the removed part.
4,268
curious...
Anyone know WHY are the wheel bolts/nuts aren't NOT Metric ?
I always thought 'Tractor Made in Japan, metric', loader, USA, normal nuts !
They wanted to drive us Nuts for revenge.
The Kubota doesn’t bother me much on this issue. What drives ME nuts is on my American Cars/Trucks when it takes SAE AND METRIC just to remove a battery or air cleaner!
onabota
BX2680, BX2822 front mount snowblower
Jan 24, 2024
Earth
I checked all the parts diagrams for the 2822 front mount snowblower while looking over the equipment and didn't find a match.
The bolt is cleaner than most on the snowblower. I'm beginning to think fell off the tractor.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Congrats and I bet you finally got a good nights sleep.
4,268
whew !! Now I can sleep too !!!
That one came off my BX23S as well. A little nail polish (poor man's locktite cures another sleepless night !
I think you meant “poor woman’s loctite”….?? 😝
