My L245DT will not start, checked through the Posts, found post on looking in Inspection Cover helpful
Don P
Kubota L245DT
Nov 25, 2025
9
Florence, MT
The response post from Darren Todd to John146 on June 17, 2014 said "you will see a rod running the length of the pump with springs at both ends. I opened my fuel pump inspection cover and see no rod running the length of the pump. I see the ends of the lever fork, one appears to have wear mark on end. Did I loose this rod somehow? Now what? Also I tried to loosen nuts on the injectors to check fuel flow to injector, they are seized. I am soaking them with liquid wrench now. The price I pay for 45 years of not turning those nuts. Suggestions appreciated.
2,541
I have no idea what you suspect is missing but I doubt that could just fall out.
Go here and look under the engine section for the injection pump diagram for what is in the injection pump.
And explain what “my L245DT won’t start” means in more detail. I think you means that it spins but won’t fire off and run since you seem to be asking about the fuel side of the engine.
See if any fuel is running to the injection pump by loosening the air vent valve on the pump. Some should be coming out. But I would suspect that the tank has rusted inside and is clogged somewhere (outlet, filter, lines). So in general see where you have fuel running to or not by taking fuel lines off and seeing the flow volume.
I also suspect that it has recently gotten cold in your area and your fuel may not be winter blend and is gelling??
Tell us more of what recent history and what troubles are now occurring and you will get more information back.
Don P
Kubota L245DT
Nov 25, 2025
9
Florence, MT
w
Thanks for your reply. Yes the engine turns over, usually have some white smoke out of the exhaust, not now though. A little history, tractor did run and start well prior to this problem. Yes I did bleed the fuel line at the filter and fuel pump, volume of flow might be issue though. Seems fuel came out in more volume in the past. I'll try draining fuel tank and lines watching for fouling.
the part I was referring to was a rod supposedly visible after removing the inspection panel on the fuel pump. It was referred to in a post by Darren Todd, long term member of this forum, he said it should move back and forth and have springs at both ends, it is on the fuel side of the pump in the speed control group of my engine schematics. It moves with the throttle levers. I see no movement of any part, in that inspection port, when moving the throttle levers. Thanks again for your suggestions. OH not cold enough for gelling problems yet. It will have to wait till after Thanksgiving.
2,541
Go to this thread, page 31, post 612 and there are some pictures that are looking through the inspection cover on a L295. The parts are NOT assembled properly so don’t think that yours is incorrect if it looks different than the pictures! (Ignore most all of that thread since it seems there was a lot of chain jerking going on)
You can get a work shop manual (WSM) here. Look for the L185…L245 … manual
Don P
Kubota L245DT
Nov 25, 2025
9
Florence, MT
Hey Russell,
I checked my fuel in the fuel filter and it was clean, also opened the fuel cock with filter off and got great flow to the filter. Doubt I have a fouling problem from fuel tank. After bleeding system to the fuel pump, I also cracked a high pressure fuel line to the injector (some posts indicate a potential for air in this part of fuel delivery) and got no fuel when cranking the engine. MY question of the day is would cracking one fuel line to an injector be sufficient to see some fuel while cranking engine? the injector nuts are real tough to access and break loose. I picked on the easiest which was no cake walk either.
I check that post 612 0n page 31. weather here in mid 30's not bad.
9,777
If your getting fuel to the injection pump, and getting no fuel out of the injection pump, you have a linkage, governor or Injection pump issue.
2,541
If you run out of fuel at the injection pump, then air will be pumped into the lines to the injectors.
You then must bleed that air out to get the engine running properly again. The air is compressible and cannot inject fuel through the injectors (It acts like a dash pot (shock absorber) in the fuel line).
I never loosen the lines at the pump from fear of making some unintended adjustment to the pump by rotating the ”parts” under that small line nut, if it is hard to break loose. I did replace the injectors, and lines between the pump and injectors one time. The lines looked a bit corroded inside. When doing that, I held the larger nut (on top of the pump) with a larger wrench and easily broke the injector line nuts loose without moving the large nut. (I may have put some marks so I was 100% sure they didn’t move.)
I loosen the nuts at the injectors and pull out the decompression rod and set the throttle to full RPM position. I see a mixture of fuel with air bubbles when cranking the engine. After a few crank/cool starter sessions, the bubbles will start to be less and less and then disappear. This usually happens at one injector first so I then close that injector line nut. I then get the air out of the other line completely and close that injector line nut. Then wait for starter to cool down and start the tractor. I then, of course, lower the engine RPM and while it is running I crack each individual injector (one at a time) to see if there is more air in the line and that the engine RPM decreases on each cylinder, ensuring that it is injecting fuel. (Last step is probably not required but that is what I do!)
You have not really told us what happened to your tractor to stop it from starting. Please do that and you will probably get more useful information back.
The injector lines will almost always eject some fuel but never a whole lot. Sometimes it is just fuel, but there is less fuel and more air if it has died from lack of fuel.
The nuts on my tractor are easy to access at the injectors and I think I have seen pictures of L245 that are similar easy access there.
Don P
Kubota L245DT
Nov 25, 2025
9
Florence, MT
Your reply is appreciated!!
Wolfman, Can you give me advice on additional tests-fixes to the governor or linkage issues? I suspect it might be something like that because tractor was running fine up until this happened. I would think a fuel pump problem would occur with some warning power loss, etc. The external linkage is working fine. With the fuel pump inspection plate removed, I can see the ends of fork levers and when I increase the manual throttle controls, I see the closest fork lever and spring move with the manual throttle controls. My Operators Manual schematics are somewhat confusing on how all the linkages function internally. Is it time to throw in towel for a real mechanic? Any help appreciated!
9,777
With the side plate off, take a picture of what you see.
9,777
There appears to be a lot of rust in there?
I don't like the look of the back of the fuel rack (arrow)
9,777
When you move the throttle control (blue)
Does either lever ( Yellow, or Green) move?
Don P
Kubota L245DT
Nov 25, 2025
9
Florence, MT
the green does not move (spring attached to green moves), yellow does not move, blue moves as well as the center bolt on blue. I suspect rhis is not right! What do you think?
9,777
Rack is stuck closed.
Let me dig up some pictures to help you out.
2,541
I also suggest that @Don P check all the throttle linkages to be sure they are free moving and will allow the fuel rack to move. I know on my L@85 there is a finger lever that is pulled up to shut the tractor down by pushing the fuel rack and stopping fuel flow. If that linkage is frozen in the cut off position it may be able to hold the fuel rack closed. (I don’t know if it would hold it or not butitis easy enough to look at and see if it moves easily.)
Don P
Kubota L245DT
Nov 25, 2025
9
Florence, MT
Hi Russell, I think it appears the fuel rack is frozen. No movement of either fork in the inspection window, when throttle is increased. The exposed linkage to the speed contol lever and associated double nutted bolt move with throttle movement. Yes my L245 has the same manual stop lever. How do I proceed to unfreeze the rack? Can I work in the inspection window? Which direction do I apply pressure, it appears I apply pressure to the rear of tractor on the fuel rack. Any hints on how, with what to get rack moving? Wolfman is going to send some helpful pictures.
I appreciate your help!
Don
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
688
297
Herald Calif.
PB blaster is what I have found to work. Spray the rack and let it soak for a day.
2,541
@Don P
Yes, work (carefully) through the window you took the pictures through. I would spray it with PB Blaster and try to move it around in both directions. I think the throttle control will move it towards the rear of the tractor to increase the fuel flow. But use the throttle control to verify which way it wants to move the rack.
Don P
Kubota L245DT
Nov 25, 2025
9
Florence, MT
well I am back after some more tinkering with the linkage on my L245dt. I sprayed the linkage inside the fuel pump inspection window with BP Blaster for 3 rd day now. I am getting movement on the fork with the hole and attached spring to the front of tractor when I operate the manual shut off as if I was shutting off the tractor. When I pull down on the shut-off lever ( opposite direction to shut off tractor) I get a little movement on the pointed fork and the pin that fits into it's slot to the rear of the tractor. The throttle lever produces no movement of the forks. attached another photo slightly different view. Is the fuel rack the bright metal bar to the back?
9,777
This pin is the rack.
If the pin is moving, the rack is moving.
