I was pushing some brush into a pile and apparently there was a small tree trunk (1.5" diameter) still attached to the ground. When I backed up I heard an noise and turned the tractor off immediately. The stick up must have been at just the right angle and got up under the tractor and went into the fan, braking off all of the blades and then puncturing the radiator. I saw coolant streaming out and into the ground. I called my local Kubota dealer and they said the radiator would have to be replaced, it was plastic and could not be repaired. My question is if this is something that I could order online and pull and replace myself or should this be a dealer service item. My initial review looks like quite a process, so I'm torn. Looks like I can buy and aftermarket radiator on line for around $500usd. Suggestions? Any estimates on the dealer costs for such a repair? Is it truly a replace scenario? Thoughts.
