M7060 Idle is high. How adjust?
2,869
Has IT always been there? OR has it gone up over time?
Looking it up - that is spot on btw
3,654
That’s a fairly new design (2013-2024) … There’s a reason for that idle-speed : Emissions Controls.
Even if you could change it, you’d likely be doing your emissions controls no favors and it’d end up costing you.
dhcole99
M7060
Oct 21, 2021
27
Ontario, Canada
It has increased by about 200-300 rpms over the last few months. Regeneration cycles have not changed. Not sure if it due to 85+ temp over the last few weeks. More concerned about higher rpms on start when it is 30 below zero.
Botamon
Mar 26, 2018
401
755
Winnemucca, Nevada
Idle speed on my 9 year old M7060 has always been 900 - 1000 rpm. If memory serves me correctly that's what it is set to idle at, at the factory.
whitetiger
Nov 20, 2011
3,280
1,689
Kansas City, KS
Idle is consistent at 1000 rpms and does not go lower. Any suggestion how to adjust lower? 1900 hours.
Idle speed spec for the M7060 is 950RPM to 1000 RPM.
The engine is a Common Rail, Tier 4, so you can not change it anyway.
