I have a M7040 with the hydraulic shuttle and have a couple questions
1. I know you don’t have to use the clutch with the hydraulic shuttle, so is it best to go to stop in neutral either for a second or two before changing directions, come to a complete stop before changing directions or just go straight to the opposite direction position with the lever without stopping in neutral first?
2. When changing directions with the shifter without using the clutch is it normal for there to be a slight pause before the tractor lunges in the selected direction?
Thanks
Josh
Thanks
Josh
