NIW I don't get to do it very often.I meant no multi disk dry (mechanical) clutch... Heck now I'm confused!
Still blaming it on Dave...
Dave, quit confusing me!
I think the confusion arose when I introduced my experiences with motorcycle oil bath type multi plate clutches as a way to show any multi-plate unit can be damaged.
Kubota 7040 with hydraulic shuttle has the rotational springs to deal with engine vibration to the drive train just in a fixed assembly at the flywheel. See #3 in illustration.
From my WSM:
The damper disc (3) helps ease the shock load when engaging the shuttle clutch.
The belleville washer (cupped spring washer) (4) helps ease the engaging shock together with modulating valve effect.
The hydraulic shuttle clutch, which switches forward and reverse running, function as the traveling clutch. When the clutch pedal (2) is depressed, the clutch spool of shuttle valve (8) moves via the clutch cable (9)
I think for the M7040, the clutch design varies model to model as this dry plate design shows up on Messick's. Possibly for a synchro shuttle.
My original invoice has M7040DTHSCC1
Dave
