I tried starting my M5400 for the first time since winter today. It ran for about a minute and quit. It was in the low 40's (°F) today.
I checked the fuel filter and it had water in the bottom of the bowl and needed changed. I replaced the fuel filter and have bled the fuel hoses to the fuel lift pump and to the entrance to the fuel injector block.
I have opened up the fittings on top of the injectors to try to bleed the line further, but nothing is coming out. I got a little bit of bubbling and white foamy watery diesel out, but then nothing from any of them when I crank the engine. I would think, fuel should be spraying out?!?
Anyone have advise on this? How can I tell if the fuel lift pump is bad? How can I tell if the injectors are bad? I'm at a loss at this point and wondering if I should start ordering parts...
