I need a battery for m125x, it's 1045 cca, looks like $400 plus, is there another battery I can use other than the factory brand, part number is 3f999-02180. Thanks for your help.
Measure the physical size of the battery and compartment, then go and get the largest CCA battery your wallet can afford! Check the posts on the battery too - make sure that posts will allow cables to reach.
I put a Optima D31M blue top in my M9000. It has 900 CCA / 1125 MCA plus has the accessory post which sure makes it easy to hook up extra stuff like bale monitors and such.
