Looking for some ideas
Dieselbob
BX 2230, LA211 loader, 60â€￾ MMM, 2â€￾ wheel spacers, grille guard, gauges, bucket e
Nov 17, 2014
196
Fort Wayne IN
I use my BX with the loader around the yard constantly as a motorized wheelbarrow so to speak. The one problem I have is that I am always trying to carry a shovel and rake around with me. If I hang onto them, they get in way, and if I stand them on end, I have had them smacked out of my hands by tree branches. If I lay them in the bucket or across the loader arms, I hit a bump and they fall off. The thought of using some PVC pipe to make holders has crossed my mind, but where and how to mount them? If anybody has some good examples, or at least good ideas, I'd like to know. :)
bmblank
Mar 4, 2015
756
464
Cadillac, MI
drill 2 holes straight through a length of PVC, then come back and drill the holes on one side of the pvc big enough to accept the heads of screws or bolts with whatever tightening method you're using (ie, the hole needs to be big enough for your socket driver). or, alternatively, you could also wrap hose clamps around a vertical member and lash the pvc section to it that way.
Sent from my XT1254 using Forum Fiend v1.3.2.
ShaunBlake
Dec 21, 2014
899
drill 2 holes straight through a length of PVC, then come back and drill the holes on one side of the pvc big enough to accept ...
That's a great idea! And make the second holes big enough to get a socket to drive the bolt. Or, better, use carriage head bolts so the shovel and rake handles don't bang on them when you put them in the tube.
I recommend against drilling into the FEL arms, and as well, the ROPS. Putting a pipe on them should be done with big hose clamps (or tie-wires, if you can pull 'em tight enough), or with ClickBond fasteners.
10,197
Tubes mounted to a ballast box is also a great way to haul the rakes and shovels around. ;)
2,976
Here is a thought -
using your pvc pipe - zip tie it to your vertical frame mount that supports your bucket- I use these for chains, but I bet you could take two pieces that are 2" in diameter and place them side by side - and have a set on either side. Now true the rakes and shovels would be up in the air, but probably not any higher than the rops. Just a thought - total cost would be less than 20 bucks. The zip ties are the kind you use in HVAC and are bought at lowes.
bmblank
Mar 4, 2015
756
464
Cadillac, MI
you could also attach the pvc to the lower end of the rops such that the tips of the shovels ate right around the top of the tops, if they'll line up like that, of course.
edit, I like the chain container.
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
Here is a thought -
Damn! How do you keep that FEL so grease free??? Mine slings extra grease all over the place.
3,392
I must agree, I looked at another B7100 with a B219 FEL that had 2 extra bolts all yucky-puckied up with silicone seal on the right-hand upright. (the RH upright is the hydraulic tank) The guy has tried to mount a fire extinguisher. Can you say Tater-haid? I knew you could.:rolleyes:
