List of Grey Market Models & North American Equivilant
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Here is Kubota's list
http://www.kubota.com/priorproduct/GrayMarketList.aspx
Goal is to start listing the models in above link ALONG with their North/South American equivalents, notes, hints etc.
So start putting in post here equivalents and I'll try to organize somehow in this thread. These could be links to post or threads that already discuss an equivalent. I say that cause I know there is a ton of answers to equivalents already in here spread out all over this forum. Idea is to get it organized in one easy to use place here in this top post.
B5000 ....................... B6000 (A B6000 can also be a grey market) *edit by NIW
B6000 ....................... B6000 *edit by NIW
B7000 ....................... B7100 (Some aspects) *edit by NIW
B7001 ....................... B7100 (Some aspects) *edit by NIW
L1-22 (Sunshine).........L2950 should be similar. Vic believes they would not have even made a manual for the L1-22.
L126 ........................ L2650 is similar
... Major difference is the PTO. Other versions will only have a 1 or 2 speed PTO this) has 4 speeds, most implements will run at speed 1 or 2 if I remember right. (Thank You North Idaho Wolfman)
L1500 ....................... L175. same parts across the board (Thanks Daren Todd)
L1500DT..................... L225DT. same driveline (Thank You Daniel.Ray77 )
L1501....................... L185. 90% of the same parts. Where it's sketchy is the gears, since the l1501 has the creeper gears where the l185 doesn't. (Thanks Daren Todd)
L1501DT ................... L225DT (for the tranny cross reference, not sure about rest)
L2000 ....................... L225 helps a little
__________________
Jayke73
Chicago, IL USA
Re: List of Grey Market Models
THANK YOU for starting this list! I know nothing about tractors but my father-in-law has a Kubota tractor on his farm in New Zealand. We helped him fix the hydraulics, but it was very trial-and-error because all the labels and instructions are in Japanese. My brilliant idea for his next birthday present was to get him a manual in English, but that was before I knew what "gray market" meant, much less how impossible it would be to get any information or help from U.S. dealers. I'm really happy to have found this website and I think we'll get him a lifetime OrangeTractorTalks.com membership, as well.
My question: Is the ZL1-20 the same as an L1-20?? What's a Monroematic? According to the photo I took of my father-in-law's tractor, the model is a "Sunshine ZL1-20 Kubota Munroematic." The only "ZL" reference I have found is from used tractor dealer in Europe. Any info on what model manual(s) might be relevant/helpful would be greatly appreciated! Thank you!
These are links to the same tractor that my father-in-law has:
http://www.usedtractors.gr/product/kubota-zl1-20-sunshine-4x4-20hp/ and http://tractor.eu/machine/82/kubota-sunshine-zl1-22#prettyPhoto
cedicol
pepingen België
So, I have bought a grey one as well. Little did I know when I bought it. Could you please tell me what cross reference my gt3 is. I really hope you can help me because when I ask this at a dealer they just say, we can't help you. Good bye sir.
bcp
BX2360
Apr 20, 2011
644
79
SW WA
Monroematic: a hitch control system
OTT Monroematic
TBN Monroematic
From the translation link below:
Option which allows one to set rotary's plowing horizon level. Japanese farmers use the option so as to make plowing ground flat.
Bruce
9,238
You can start by helping us out with starting a thread and posting pictures and specs like gears, engine size (CC# is cast into block behind the hydraulic pump, also on some is stamped into the block by the injection pump), Tire sizes, and PTO speeds.
I'm pretty sure there is no straight non grey cross over, but maybe someone can give you more info.
