On my L1501 the headlights are the plastic push and turn sockets that have the little legs snap off them and your bulb dangles inside the grill like a Halloween pumpkin light.
I decided not to do the definition of insanity and keep replacing them hoping for a better result. And I wanted to try LEDs.
So I notice I had a couple of 4" trailer backup LED lights in the resource pile, brand new and with the rubber mounts.
I found that with a little circumcision of the outer rubber, I could set the rubber in backwards and mount the lights into the rubber ring as they were intended, just facing the opposite way.
In the first and second picture you can see the trimming of the rubber ring, and then looking into the chrome ring from the backside with the rubber installed.
Third picture shows taking a zip disk and cutting away the offending reflector to clear the power plug.
Last one it is ready to mount on the tractor.
