lights -gauges out and wont start
brett
b3030
Dec 12, 2013
lenoir city tn
i have a kubota b 3030 , and i turned on lights in about 5 minutes they and all gauges went out, then after i shut tractor off it wont start now, it just clicks once when turning key on . help what can it be , was told could be slow burn fuse , what do you think it is ?
thanks
5,169
Is the click loud like a starter relay or a soft click like a light relay?
brett
b3030
Dec 12, 2013
lenoir city tn
its not the starter relay , kubota service said poss be the slow blow fuse ,
but they want 150 bucks to pick up and bring back .
clicks when you turn to ist position, when trying to start theres no sound,just nothing
5,169
The fuse your looking for is around the starter, but I don't think that's your problem, normally when that fuse goes out nothing happens, no clicks at all!
brett
b3030
Dec 12, 2013
lenoir city tn
i will check battery and let you all know, also ill check fuse , which one kubota service dept said could be prob. one also said turning lights on prob drained the batt to far [if it was going bad] and shut lights off and gauges off.
but its funny no problem before always turned over fast and started right up,
besides only changing two busted hoses for backhoe havint had a problem with this tractor and have about 700 hrs on it
been a workhouse and love it.
jimsdeere1010
L4600 4x4 FEL, WD 45, WD 40 Allis Chalmers
Nov 11, 2013
22
Wayland, Ia
Brett,
If you were running your lights and they and the gauges went dead. The engine would continue to run until you shut it off. You might have a bad alternator, that couldn't keep up with your lights and when you shut it off and tried to start just a click. It's just a thought, in case you change batteries or charge that one and it happens again….Jim
BAP
Dec 31, 2012
2,534
672
Another thing to check, would be to be pull off the battery cables and clean the ends and the battery terminals. Doesn't take much corrosion build up to reduce the amount of current flow. Also, pull off the ground cable where it hitches to the frame or engine and make sure it is clean to get a good ground. Over time, a little corrosion or rust build up can have a big effect on how the battery charges and how much current is passed on to the electrical system.
brett
b3030
Dec 12, 2013
lenoir city tn
Brett,
ok i will check that in the am
brett
b3030
Dec 12, 2013
lenoir city tn
ok i will check that in am if its not raining tks
2,851
theres plenty of knowledgeable folks here
Guess that pretty well excludes me,,lol
brett
b3030
Dec 12, 2013
lenoir city tn
well tested battery with multi meter and had 12.45 volts and running 14.65 volts , so i think battery and alt are ok .wouldnt start by jumping battery with my van .
problem was 10 amp fuse for lights was blowen, i put in new one in and started right up.
i also noticed that when i turn on turn signal the 2 dash turn signal indicators lit up. so i turned off right away,
so now i believe i have a short in the lighting some where.
how do i check for that ??
also the 4 way flashers worked . didnt turn on lights , didnt want to blow another fuse.
thanks for the help
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
You need a wireing diagram to see everything thats on that circuit .
Sent from my SCH-I605 using Tapatalk
